Question about HP Officejet 9110 All-In-One InkJet Printer
HP Officejet 9110
Where can I buy the starter cds from for this product. All of the functions are working except the scanner. I have tried HP at least 15 times and they are useless.
  • 2 more comments
  • bobbydeansow Jan 01, 2009
    can not find the installation disk for my hp 9110 office jet printer
  • Eric Sandbo Jan 27, 2009
    Me too. I thought VueScan (www.hamrick.com) would take of it, but VueScan uses HP's drivers.
  • steng Apr 06, 2009
    I bought a used hp9110 all in one printer without starter cd's. where can I buy or download them.
    thanks
  • steng May 11, 2010
    what is the solution, where can you find the starter cd's for the printer
Where vcan i get the installation disk for my hp 9110 officejet all in one printer
Posted on Jan 01, 2009
Call HP technical support and you can purchase the start up disk thru them . I purchased it for my 9110 and it cost me 17.00 and change. Shipped it 2 day air. But do not make the same mistake as I.... there are 2 start up disks make sure you order both...Make sure they send you both because I am not having a problem getting them to send me the 2nd disk
Posted on Jun 04, 2009
My hp psc 1410v all in one printer wont scan to my computer
THIS MIGHT HELP I LOVE OLD SCANNERS AND ALL IN ONE PRINTERS. MOST OF THE TIME YOU HAVE TO GOTO MY COMPUTER AND SCAN IT A DIFFERENT WAY. LET ME KNOW IF I CAN HELP FURTHER.
Mar 18, 2014 | HP PSC 1410v All-in-One Printer
HP 7410 All-in-One Printer A 'Scanner Failure' message is desplayed on the printer's front panel
I know i'm not going to get 4 thumbs up for providing this resolution because it seems like a hardware problem but what the heck you need some sort of help so here goes.
This error usually occurs when trying to scan or make copies. The scanner bulb is not hot enough or the electrical conditions are not suitable for the HP All-In-One product. Follow the instructions listed below to resolve this failure. The scanner lamp lighting should be viewable under the scanner glass right or left corner.
  1. c00439542.jpg 1 - Scanner lamp lighting 2 - Scanner glass If the scanner bulb does not light up, the HP All-In-One product may be defective.
  2. Make sure that the room temperature is suitable for the HP All-in-One product. Perform a Power Cycle on the unit by following the steps below:
    1. Turn the unit off.
    2. Unplug the power cord from the unit.
    3. Wait 30 seconds, and then re-connect the power cord to the unit.
    4. Turn the unit on.
    Check the power connections:
    1. Make sure that the unit is connected directly to the wall outlet and not to a power strip.Try a different wall socket.
    2. Every PC provides a standard power cord; it is possible to use it to check whether the electrical failure is prompted by the cord or not.
  3. If the Warming up or Scanner failure error messages persist, please move the unit to a different room or building to verify that the building (or room) is grounded properly.
  4. If your HP All-in-One product uses a external power module, check the power module part number against the part number listed in the User Guide to ensure the proper power module is being used. If both part numbers do not match and your product is still under warranty, please click the Contact HP link at the top of the page. If your product is out of warranty, please click the How to Buy link at the top of the page. c00458738.jpg
  5. Perform a Partial Reset by following the steps below:
    • Unplug the power cord from the HP All-in-One product.Press and hold the appropriate button combination for your HP All-in-One product. The appropriate combination for your model can be consulted in the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-in-One unit displays the Partial Reset message.
    Make a test copy of any document.If this copy is successful, the scanner mechanism is functioning correctly.If the error appears again, Follow the below troubleshooting
Noisy scanner This failure can occur when the HP All-in-One product is initializing.Every time the unit is turned on, the scanner carriage should move. Sometimes, when the scanner carriage returns to its home position, the carriage could crash and make a loud noise.Within a few seconds, the unit gets blocked, and the front panel display shows a Scanner failure message.Scanner noise could also be caused by the scanner sensor inside the HP All-in-One product being damaged or not properly in place.To solve this failure, follow the steps below:
  1. Perform a Power Cycle on the unit by following the steps below:
    Make a test copy of any document by pressing the Start Copy (black or color) button.
    • If this copy is successful, the scanner mechanism is functioning correctlyIf the failure remains unsolved, skip to the following step.
  2. Perform a Partial Reset on the unit by performing the following steps:
    • Unplug the power cord from the HP All-in-One unit.Press and hold the appropriate button combination for your HP All-In-One product. To know the proper combination for your model, check the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-In-One unit displays the Partial Reset message.
    Make a test copy of any document by pressing the Start Copy (black or color) button.If this copy is successful, the scanner mechanism is functioning correctly.
  3. Now if this still doesn't resolve the issue then it's a definite hardware problem my request would be regardless of the thumbs up,call up hp at 1800-474-6836 and ask for their upgrade machines because u'll get a machine with a 50-60% discount and an extended warranty with a 70-80% discount or u may get a warranty for the next two years for $1....Sorry if I can't help you
Oct 05, 2010 | HP OfficeJet 7410 All-In-One InkJet...
The scanner keeps jamming. i try to scan form the document feeder &the papers keep getting stuck. It will not complete a scan!what do i do?
In summary: * Very unintuitive, convoluted and unpleasant to use (same on Win2K as XP) - sometimes the SW hangs during scan and needs a reboot - sometimes the SW crashes with a dialogue "try reinstalling HP software", and needs a reboot - sometimes it scans and after conversion to pdf
Advantages: I cannot see any advantages with this product
Disadvantages: Software is convoluted and unreliable, paper jams are difficult to clear
function showHideReviewText( sType ) { if ( sType == 'more' ) { document.getElementById( 'review_text_full' ).style.display = 'block'; document.getElementById( 'review_text_short' ).style.display = 'none'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('less'); }; } else { document.getElementById( 'review_text_full' ).style.display = 'none'; document.getElementById( 'review_text_short' ).style.display = 'block'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('more'); }; } } ...with a dialogue "try reinstalling HP software", and needs a reboot
- sometimes it scans and after conversion to pdf every page is blank
- very occasionally it scans a document properly
*If the sheet-feeder jams is says to refer to the documentation to clear it, which doesn't exist. There is no way to clear the jam except to pull hard & hope. No levers to release it like one would expect.
*Frequently has error ...
...cycled to work again.
Everything has to be started by pressing a button on an application called "HP Director". There are 4 apps started from this:
1) Scan Picture
2) Scan Document
3) Make Copies
4) View & Print
also Help
also Settings (which are used in conjunction with settings found in (1) and (2)!)
- Each application has to be exited to return to "HP Director"
its a worst scanner
and prone to jamming problem
Jun 09, 2010 | HP Scanjet 5590 Flatbed Scanner
Hp 6110 scanner making noise i can do any thing else because of that scanner light doesn't move, move little on scanner glass then come back on right hand side and keep making noise some time i can see...
If you cleaned the scanner glass before the problem began, it sounds like you messed up the homing strip underneath the glass. The scanner is trying and trying to find its home position and it can't. There is no way to disable the scanner to use the other functions. This is the downside to All-in-One machines. If one function (most commonly the scanner) stops working the entire machine won't work. I own a Cartridge World ink refilling store and I always caution people against buying all-in-one machines for this reason. It sounds like you'll need to buy a new printer, unless your printer is magically still under warranty you could call HP and ask what they can do for you. They'll probably just recommend you buy a new machine anyway.
Feb 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Left and righ hinge is broken on my HP officejet 6210, where can I find
I "inherited" a 6210xi because BOTH hinges were broken... poor and weak plastic design that breaks if the operator tries to raise the access past about 40 degrees for access to ink cartridges... of course after the hinges break it doesn't close properly to start again (except with creative taping!). In my pursuit of these parts I found that the lower hinge part (broken) Part#JB6100289A is actually a Samsung part for their SCX-15 printer/scanner. It was also interesting to find several of these 6210xi's for sale on eBay and other places for $10 or less as "broken, parts only" and AMAZINGLY, it was the same broken hinge part that put all of these out of service. Found the HP Part number as RG5-6317-0000N but couldn't find anything except to buy either the Top half of a whole 6210 or the Bottom half for hundreds of $$'s, far more than the WHOLE new working item would be. UED.net listed the part as "non-stocking" at $2.27 each, available Aug 8, 08, but it turned out to be that they are negotiating for access to that parts and VIOLA! a few months later I received SIX hinges at $2.27 each plus shipping. You have to be creative to keep your old stuff working.
Feb 09, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
HP Scanner 3970 will not scan slides
If the reason for trying to use the software is nothing more than to have a photo editor / cropper / etc... buy a different program!
My experience with HP has been great, except for the fact that their software is ridiculously large, and filled with fairly useless add-ons. I have used various imaging software/photo editing software for many years, but rarely ever that of the scanner's manufacturer because of functionality. If you want a decent program, check cnet.com, under downloads... you can find wither freeware or introductory software that rivals most basic manufacturer's products!
Aug 27, 2009 | HP ScanJet 3970 Flatbed Scanner
HP Officejet J5780 scanner communication error
I had this problem too, and after a while just gave up on the uesless HP interface, and went to the simple but efficient Windows Fax and Scan program on the Start>Programs menu.
Jul 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Hi, my one of customer need a printer for printing CD or DVD (SURFACE)
There are two different types of photosmart Printers with HP which can print on CD and DVD
First: HP Photosmart C5280 All-in-One Printer, Scanner, Copier which can Emblazon CDs and DVDs 1 with your own images and text, Check the link Below:
http://www.shopping.hp.com/product/printer/Photosmart/1/storefronts/Q8330A%2523ABA
Next is HP Photosmart C8180 All-in-One Printer, Scanner, Copier
Prints true-to-life photos, laser-quality documents, custom designs on CDs/DVDs, Check the link bellow:
http://www.shopping.hp.com/product/printer/Photosmart/1/storefronts/L2526A%2523ABA
Good Luck
Nov 25, 2008 | Office Equipment & Supplies
SCANNER
"download"?? You don't download, you install. Have you considered that the scanner might not be compatible with Vista? Here's the Visioneer site: http://support.visioneer.com/products/home/EOL/8100/downloads.asp
Jun 22, 2007 | Visioneer OneTouch 8100 Flatbed Scanner
HP Officejet 9110 All-In-One InkJet Printer Logo
283 people viewed this question
Ben Johnson
