Question about Kenmore 62642 / 62644 / 62649 Microwave Oven
Runs but makes a super load pop sound with flame
Our microwave runs but made a super load pop sound with a flame in the vent above the LCD display. I immediately stopped cooking, but when we tried to cook again the pop and flame came again. Haven't tried again. Is it worth repairing or does this sound like we need a replacement.
    Problem Solver:
  • 19 Answers
Check for recall of GE microwaves here:
http://www.cpsc.gov/cpscpub/prerel/prhtml08/08110.html
Posted on Dec 29, 2008
I Started To Cook Dinner, When I Heard A Pop,, Then a Flash above the Keypad In The vent,, The Microwave works But it does Not Heat, and makes a Very load Buzzing Sound,,,, Any Suggestions
Posted on Apr 19, 2008
    Problem Solver:
  • 19 Answers
I believe the flame is caused by the waveguide cover. It is a thin semi-metallic cover that goes over the magnetron opening. My new GE microwave also had a fire, the waveguide cover was burning and being fueled by the microwaves. It turns it into a plasma fire. I called GE and they are sending a new cover. I turned the cover over and it seems to work fine now. I wonder if the cover can be installed backwards? This can be dangerous if you are not there to shut the microwave down. It could burn down the whole house.
Posted on Jan 04, 2008
  • John Saloume Dec 29, 2008
    The wave guide cover is often made of a semi metallic material. This is because many microwave ovens have convection elements that create high heat.
    Others use plastic covers.
    This should be a warranty item, call the company and request (demand) a replacement.
    I think this should be a recall issue.
    If you operate your microwave without a cover, food particles will get popped into the magnatron chamber and create more arcing.
    Report it here:
    http://www.recalls.gov/cpsc.html
I had the same problem with my GE JVM1630WB 004. It finally quit working at all. I took it apart and found the magnetron was discolored where it had been arching and burning. The magnetron was still under warranty and they had the part to me in 2 days. The part was easy to replace and it works like new now. Most manufactures warrant the magnetron 4-15 years. Please do not attempt if you are not accustomed to working near dangerous electrical sources.
Good Luck. Fksarver
Posted on Nov 29, 2007
  • 175 Answers
Someone already said it, but check the waveguide cover inside the microwave and take it out and clean it if its dirty. I have aso seen screws come loose and fall into thecooling fins on the magnetron casing an arcing. Be careful if you take it apart and let the thing sit unplugged for a while to let the voltage bleed out of the high voltage capacitor. Most newer ones are self bleeding and don't take too long to do so.
Posted on Oct 04, 2006
  • Kenmore Master
  • 9,128 Answers
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
How does this microwave exhaust system work. The installer did not use any duct work, so is the exhaust internal somehow? There is no grill on the exterior for exhaust
The exhaust fan appears to intake through a louvered vent in the bottom rear of the microwave case and output through a grease filter near the top front center of the case. You may be able to see some vent holes along the top of the case though these might be obscured by the manner in which the microwave was installed. You should be able to pop off the front panel that runs above the door but you'll need to consult the owners manual for specific instuctions.
Cheers.
Apr 08, 2011 | Bosch HMV9305 Microwave Oven
The LCD display is not showing the numbers correctly. It looks like the numbers are missing "lines", like an 8 can look like a 3, the 8 can look like a 0, etc. Any ideas?
It is the control board that needs to be replaced. The LCD display is connected to the board. If this is an above the stove microwave the problem was caused by the steam from boiling water on the stove top. you can prevent it from happening again by using the vent fan consistantly.
Dec 01, 2010 | Sharp R-1511 Microwave Oven
GE Microwave JVM1660WB - Vent went up in flames
definitely time for a new filter.
your oven may be shalvagable. Id remove it all take the cover off to inspect for damage.
I hope this helps
No more flaming foods in the micro!
Sep 27, 2009 | Microwave Ovens
My goldstar above the stove microwave popped and now won't heat. Everything else on the unit still works. Is this a problem that can be repaired? Thanks.
Did it make a loud pop like a firecracker?
Sounds like the High Voltage Diode shorted out and it probably is making a low or loud growling noise now..... ???
Sep 11, 2009 | Microwave Ovens
Microwave pops and sparks when running. Nothing
in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
Apr 26, 2009 | Whirlpool GH8155XJ Microwave Oven
Kenmore micowave oven over range
Usually this is due to your diodes going bad. I recommend replaceing the magnatron at the same time though.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Magic Chef Microwave looses power when making popcorn
That does indeed sound like the mag is overheating and the thermostat is tripping, but it's probably not the steam.
Do you feel a good amount of air flowing through the vents?
If the cooling fan is not running or the air vents are blocked, that wil allow the magnetron to overheat.
If air flow is not a problem, then you may have a defective magnetron.
Assuming it's still under warranty, it would be best to let a Magic Chef-authorized servicer handle it.
For more help from Magic Chef / Ewave : http://www.mcappliance.com/ ; Contact page http://www.mcappliance.com/contactus/contactus.asp ; Order
parts https://www.mcappliance.com/orderpart
Sep 10, 2007 | Microwave Ovens
Kenmore 62642 / 62644 / 62649 Microwave Oven Logo
438 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
