Question about Whirlpool LSB6200KQ Top Load Washer
INQUIS SUPPERB II
Hi there, Wonder, if I can get help to resolve the problem at my own! Machine doesn't spin though machine fill nicely with water & drains... If checked motor is fine, if I get instructions how to change the lid swith will be really great, thx rick
    President:
  • 878 Answers
Rick, if the lid switch was bad, you wouln't be able to drain. Sounds more like a coupler. This goes between the motor and trans. Easy fix. I will attach a photo of how to remove the cabinet and a picture of the coupler. The screws for the top console will be on the back on your model...Catriver..post back.
Posted on Oct 04, 2006
  • Ron Marek
    Ron Marek Oct 04, 2006
    First photo is the coupler, the second diagram shows the break down of the direct drive pump motor and gearcase. The pump comes off with 2 clips, move to the side. Next the motor comes off with 2 screws and 2 clips. The coupler will be attached to the inside motor shaft and trans shaft.
  • Ron Marek
    shows how to remove the cabinet. It just lifts off after you remove the 2 snap springs and unplug the lid switch harness
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My machine fills with water but does not spin
This is a good washing machine and we can help you get it repaired and working properly again.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST.
We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you get your appliance problems resolved soon.
Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 11, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSB6200KQ Top Load Washer Logo
65 people viewed this question
Sal De
Marvin
Marvin
jimorris77
