Question about IBM ThinkPad T30 2366 Notebook
Removed my CMOS battery, but the BIOS settings won't disable
I have forgotten my BIOS password and I have removed my CMOS battery for 2 days then replaced it but the BIOS settings won't cancel or disable, so i am not sure if I removed the right CMOS batterry or are there more than one CMOS batteries in the IBM THINKPAD T30. please i need help urgently, thanks for your time.
  • 488 Answers
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and
3. Your reset is now complete
There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do
please see this http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
hope it helps!
Posted on Nov 04, 2008
I forgot my bios password for lenovo t22
You will need to remove the CMOS battery to reset the mainboard. The Cmos battery stores your system configuration and your password. Remove the battery for about to 2 minutes to set your system to its default configuration and it will also disable the bios password.
Sep 01, 2011 | IBM ThinkPad T22 2647 Notebook
Tip
Problem: You do not have access to change the settings in BIOS? . Have bought a...
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Reported AMIbackdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW,BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enoxxo11nE
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
ToshibaToshiba
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•ACER/IBM BIOS
•AMI BIOS
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Toshiba
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Jan 29, 2010 | Computers & Internet
Bios password
if you remember BIOS password, you can disable/reset in BIOS.
if you have forgotten BIOS password, you need to remove CMOS battery and re-install it. password will be reseted. However, you should do it only, if you're good at computer hardware.
Apr 18, 2011 | Computers & Internet
Forgot Toshiba qosimo F15-AV201 cmos password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Jul 09, 2010 | Toshiba Computers & Internet
How can i reset my bios password for an acer aspire laptop?
IF YOU KNOW THE BIOS PASSWORD YOU CAN GO TO BIOS AND CLICK ON CHANGE PASSWORD AND IF YOU FORGOT THE BIOS PASSWORD YOU NEED TO OPEN THE SYS. AND ON MOTHERBOARD THEIR IS A SMALL JUMPER THAT SAYS BIOS JUMPER ON IT YOU NEED TO REMOVE IT AND PUT IT IN PRONK 2 &3 AND RESTART THE SYS. AND THEN AGIN TURN OFF THE SYS. AND PUT THE JUMPER BACK TO PRONK 1 & 2 AS IT WAS EARLIER. AND IT WILL REMOVE THE BIOS PASSWORD.
Oct 25, 2009 | Acer TravelMate 2300 Notebook
How to reset bios password , i forgot d password
Remove the battery on the mother board, wait 5 minutes.
Oct 15, 2009 | Fujitsu LifeBook P1120 Tablet PC
Bios password,
If you have a BIOS password and cannot remember what it is, download this program, run it and reboot your machine. Should remove the password for you. http://www.cgsecurity.org/wiki/CmosPwd
Oct 07, 2009 | Sony VAIO GRX500KA (PCG-GRX500KA) PC...
I want to remove the bios password for my dell inspiron 1420,i have tried to use the defalt password thy ddnt work,is there any1 who can tell me where to find the chip i hav to short for it to reset the...
Not only the chip inside the motherboard can do it. All you have to do to DISABLE Jumper Setting near by Lithium CR2032 Battery or else in the motherboard by removing in a second (10 secs.) Then put back again and the BIOS were back into default setting.
Sep 29, 2009 | Dell Inspiron Notebook
I know bios password but i want to remove it without removing the battery
log in bios and set bios password again hitting enter
this will reset your current password
Jul 09, 2009 | Acer Computers & Internet
Lenovo master password forgotten
i own one too, and only way to fix that is to reset the BIOS, i mean is the battery removal.
Dec 19, 2008 | Lenovo 3000 C200 Notebook
IBM ThinkPad T30 2366 Notebook Logo
1,021 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
