Question about Kitchen Appliances - Others
Light Pilot light - hot water heater
I had to turn off my gas main in order for my oven to be repaired.  Now, I cannot light my hot water heater pilot.  It is very old, a Montgomery Ward heater model srm 33713.  It tells me how to light the pilot (the steps), but I am not sure where to put the flame?
4 Suggested Answers
  • 161 Answers
SOURCE: my washer flooded my basement
I don't know how high the water got but if only the burner was covered it is probably just dirt. Try replacing the thermocouple this is usually less than $10. If the gas valve itself was wet REPLACE THE WATER HEATER!!!!!!! Never trust a gas valve that has been wet!!!!! It can seem to work just fine but get stuck in the open position defeating all safety measures.
Posted on Jul 07, 2008
  • 136 Answers
SOURCE: the pilot lights on both furnace and water heater
have then replace your thermo couplers in them it'll solve your problem its a sensor for your pilots
Posted on Nov 25, 2009
  • 103 Answers
SOURCE: montgomery ward hot water heater model SRM 33004 PILOT light won't stay lite ?
The oriface may be partialy plugged or the thermo-couple is bad.
Posted on Aug 08, 2012
Ward Floor Heater, Model 570 EDR, works but is outputting much less heat than normal. Any information about where to look, parts I might need, etc would be greatly appreciated.
"The valve stem labeled Hot at 12 oclock and Off at 3 oclock,"
Is probably the problem. I'd try wd-40 overnight to see if it would free up the valve. It worked on a similar problem outside gas grill valve.
Mar 04, 2015 | Montgomery Ward Heating & Cooling
Vaillant gas water heater - pilot light only, not lighting the main gas ring when tap is turned on..
first check to see if the thermocouple is close enough to the pilot. if it is and won't light the ring, replace the thermocouple.
Mar 01, 2014 | Water Heaters
Montgomery Ward
you didn't specify whether it was electric or gas, so i'll assume it's gas. Clean or replace the thermocouple that the pilot light heats. Yes it could be the thermostat as well.
Nov 07, 2013 | Water Heaters
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
Feb 03, 2013 | Water Heaters
We are having difficulty lighting the pilot light on our wards gas wall heater. Is there a diagram that shows where we are suppose to put the lit match and which way to turn the knob? Thanks for your help
you may have to push down on gas knob to start gas flow for pilot move flame so it licks thermo couple detector.
if thermocouple gets too old it will not generated enough power to keep relay open for pilot
Nov 25, 2010 | Montgomery Ward (223600UP) Heater
How do i light the pilot on a ward floor furnace madel 570 edr
You need a very kong wire and a kitchen match. Turn the knob on top to pilot and push down have your flame already down thru the pilot hole at the bottom of the inside of furnace. Hold for a few seconds and release knob trun to heat. This unit works on a power pile systm and generates milivolts from the flame. Rus
Dec 13, 2009 | Montgomery Ward (223600UP) Heater
We have a old Montgomery Ward five-hundred Glass Lined hot water heater Serial # SNN 1177204708 Model # SRM33331A Type Gas NATURAL GAS PRESS IN. W.C. Input BTUH 46,000 MAX SAFE INLET 7.0 RECOVERY GPH 38.6...
I believe I had the same problem with my water heater about 15 years ago. It started with a small leak, then the tank broke flooding the room. I think it would be be best to replace the unit. Water heaters tipically have a 8-10 year life.
Mar 11, 2009 | Montgomery Ward (223600UP) Heater
Kitchen Appliances - Others Logo
71 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
