1 Half way through wash cycle tripped main fuse box (not just sockets).
2. Completely emptied water out of machine manuallly :- then tried a 1600 rpm spin cycle - Worked OK! Full 10 minute 1600 rpm spin!
3. Then Did a 3 minute DRAIN CYCLE - WORKED OK AGAIN
4. Next Started a Quick 30 Minute WASH CYCLE - TRIPPED MAIN FUSE AGAIN! 3 minutes into cycle ( Water went into prewash and wash compartments ok and started to spin/wash then tripped.
5 Tried following day still tripped mains.
6. Checked for leakage under washer/dryer over a few days NO PUDDLE /DRIPS.
7. Manually emptied machine again. LOW AND BEHOLD SPIN/DRAIN CYCLE WORKED AGAIN.
WHICH BIT IS FAULTY? please
I say 100% its a short on the element or a stat on the back of the machine if it not right get back in touch with me and i give more answers good luck
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
will rate this when I have checked out element (is useful - as did not think of that part) will get back to you when sorted one or way or another. Was useful regards donna64
starts main wash, then appears to abort program
it didnt take on water as soon as i push the start button it tripped the main switch just for the kitchen socket the control panel is alight but wont change or take on water
