I have a Toshiba 50HD66 dlp that has no sound and no video, I peek in the back and the lamp show light when turn it on with the power button. so the lamp is OK it must be a power board or something. Can I have help, please?
    Scholar:
  • 155 Answers
The problem should be with the main power supply board.
first remove the main power cord of your tv from the electric outlet and attach it to some other power outlet and check .if it gives the same problem then.........
1)check the fuse on the main board .may be that fuse had blown, so you r facing this problem.if the fuse is blown replace it.it looks like mini tube light in shape and made up of thin delicate glass.
2)check the blown capacitor or bulged/leaked capacitor on the main board.if there are such capacitors check on the main board and replace them.
3)also check out any burnt ICs on the main board.if there are any replace them.
4)also check for any short tracking on the main board .if the circuit gets cut due to short tracking this problem could occur.
this all can only be done if the main board is removed after opening the tv.
it can be done by yourself if you have technical knowledge in using multimeters and soldering irons.
or it would be very dangerous to do without any technical idea.do not touch any internal part of the tv main power supply board when the power is ON the result could be fatal and its very risky.
thanks
Posted on Nov 04, 2008
  • 728 Answers
If you are good with electronics, you may have to open the back and check the connection that goes from the circuit board to the lamp and see if it is broken. You might have to re-solder it. If it is, or you are not that good with electronics, see if it is still under warranty so that it can be fixed free at a shop. You still might need to get it checked up by a profession.
    Brigadier General:
  • 3,614 Answers
Check for any burn and faulty capacicitor and resistor on the video output module. also check also for any faulty fuse on the power supply area.
keep us updated.
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
I have a Toshiba 1080i DLP hdtv.. my son & i were
the lamp exploded it happens u need to replace the lamp ensure its the exact type, the lamp is the light source and without light the dmd cannot sync colours nor pix
Jul 10, 2013 | Televison & Video
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
The buzzing sound on back burn 2 d95 lamps and red and gren light on the front
If you have not done so:
Inspect Lamp
inspect color wheel
inspect Ballast that powers lamp
May 13, 2012 | Toshiba 62HM95 62" DLP HDTV
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Electro Med Services...
