Question about Proscan PS50700 50" Rear Projection Television
The video works perfectly but there is no audio
The sound on my Proscan TV stopped working. The picture is perfect, but when the volume is turned up a popping sound is produced. I switched the TV to external speakers and hooked up stereo speakers and the same sound resulted. Is this an easy or inexpensive fix or should I look for a new TV. The TV is 8 years old. Thank you for your help!
    Sergeant:
  • 337 Answers
The best part is that you like the picture and that makes it worth repairing,before you call for an estimate tap on the side of the set and/or the jack panel to see if the sound comes back if it does react you are looking for a loose conection and the repair should not be expensive but if it does not react you might be looking at the stereo amp board and that can be expensive depending in your location,If you are familiar with tv service you can go as far as removing the back cover and taping on the chassis or in the area were the internal speaker wires conect to the chassis or the amp board but if you are not too familiar be safe and call for assistance from a servicer.
Posted on Oct 04, 2006
I have a 22 inch proscan television. i hadn't used it for about six months prior to now. The picture is perfectly fine, but the audio will not work at all. I have tried unplugging it and letting it sit...
It sounds that the audio output section circuit to your TV has the fault. The audio output IC, or speakers should be suspected. Contact any service technician. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 28, 2013 | Proscan Televison & Video
I have a cable running from my set top box to another tv. Although i have a good picture there is not enough volume on the sound. It has worked perfectly well until I had to dismantle everything . I have a...
This is not how you explain your problems to others. It should be precise. In this case, you could have said that you connected the cable between the RF out put of set-top box and RF input TV. Or Audio/video output of set-top box to Audio/video input of the TV. Also you did not mention, to which port you had connected the Vedeo recorder and DVD which are working good. Now, it may the volume level of the set-top box at low level which you can try to increase by using the remote control
If you could not sort out the problem explain how you had 'dismantled everything'
Apr 12, 2011 | Sharp 25N-M100 25" TV
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
"No Signal"... audio but no video.
Try changing the input selection on the TV with the remote.
Dec 31, 2009 | Yamaha RX-V740 Receiver
PT-52LCX65-K Panasonic rear-projection LCD No Sound
My panasonic did the same thing. turns out my coaxial cable hooking up the cable from the wall was bad. Once i unhooked it from the wall, the sound popped. I wiggled it a little on the receiver end on the wall and got sound. So try replacing your cable box cord and see if it fixes it.
Dec 15, 2008 | Panasonic PT-52LCX65 44" HDTV
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
No Volume Unless
you might want to take it in to a repair station. The buttons on the front might need replacing.
Jan 25, 2007 | RCA F36668 36" TV
Proscan PS50700 50" Rear Projection Television Logo
151 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
