IBM NetVista M42 PC Desktop Logo
Anonymous Posted on Nov 04, 2008
Ethernet driver problem - IBM NetVista m42
I recently reformatted a friends IBM NEtVista m42 computer. I have reformatted a few computers in the past (not IBM) without problems but for some reason I am not having much success with the ethernet driver.
I have downloaded drivers from IBM's site for the model number and installed them on the computer but it doesnt seem to work. I have tried numerous drivers, none coming back as fails but yet none working either.
Everytime I restart the machine, it prompts me saying I need to install the "Ethernet Controler" driver which comes up under "other devices" in the device mananger. The drivers I install do not come up anywhere in the device manager.
Any help would be greatly appreciated as I need to fix this for him ASAP.
  • 5 more comments
  • Anonymous Dec 20, 2008
    Need the ethernet driver for a ibm 8315-42c
  • Anonymous Jan 19, 2009
    I've got the same problem. I can't find the proper driver anywhere. I believe its linked to the PCI Simple communications driver which is missing also, along with the SM Bus controller and the USB Controller
  • Anonymous Feb 06, 2009
    pelo amor de Deus alguem me ceda o driver de internet da placa ibm 8305 netvista.
    obrigado
  • Anonymous Feb 13, 2009
    i need 1 for 8305
  • Anonymous Apr 07, 2009
    I Have the same Ethernet problem on IBM netvista 8319-21u comuter.
  • Anonymous May 07, 2009
    Am looking for recovery CD for my NetVista M42 8305
  • Anonymous May 11, 2010
    Is that XP? What is the exact model number - it will be just below the intel inside sticker - well hidden under the panel - you have to really look for it.
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Feb 03, 2010
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060667
Points
15385
Once you download the drivers, they are placed in a folder called IBMtools on your root directory C drive. The drivers do not install automatically like most conventional driver downloads. You have to go into the control panel and click on Performance and Maintenance then click on System. When the System Properties window opens click on Hardware, then device manager. The devices for which the driver needs to be installed will have an exclamation point over them. Right click on the device you want to install and click update driver. It will ask you if you want to use windows update to which you can reply NO, especially if you are trying to update the network adapter (in that case you have no internet connection so windows update will not work). Click Next and select the option to Install from a specific location and click next. When that window opens Select the option to search for the best driver in these location. Check the box to Include this location in the search and Click Browse. You should browse to the folder that contains the driver you downloaded. For example most likely it will be C:\IBMTOOLS\Drivers\xxxxxx. xxxx is the name of the file driver you downloaded. Refer back to the IBM site if you forgot the name or click on my computer and navigate to the ibmtools/drivers folders to find it. Once you have the xxxxx replaced just click next and voila it will start installing the driver.
I need the drivers of netvista 830721G
Try this link. http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42771
Driver download option of the left list of menu items.
1helpful
2answers
Netvista M42 Ethernet Driver
download the drivers from here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-51215.html
1helpful
I need a video, audio, and ethernet drivers
here is a link you can download the drives from lenovo.
http://www-307.ibm.com/pc/support/site.wss/MIGR-4MVU6P.html
Just look up your model and follow the links.
If this helps you please leave a vote on fixya
2helpful
My computer is IBM 8303k12 but i have'nt Sound card driver plz help me to provide sound card driver. thanks
Hi!
The correct name of your IBM is IBM NetVista M42
And here are the drivers you need
http://www-307.ibm.com/pc/support/site.wss/MIGR-42954.html
Good luck
Nic
DONT forget to RATE me
Motherboard driver
Please check this link and download it.
Thanks
6helpful
4answers
Cannot install Drivers for IBM computers
lets start with the ThinkCentre A50 8175. download and install the chipset drivers first.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-60642
after you reboot install the network driver.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-55649
If this works rate me and we will continue
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
