Question about 3Com SuperStack II advanced RPS (662705388786) 100-Watt Power Supply
Bass tone problem
Have a tinny sound with 2 amps.Accoustic 140 and Sunn 200s. 3 bass guitars all sound exellent on other amps. All sound very tinny and hollow on my amps. Have tried many cords, had the individual speakers tested, they are perfect. On my amps, they don't move. Plenty of volume, but the slightest turn up of the treble knob on the instrument gives it a tinny, metalic sound. Switched the 2 speaker wires and it made an improvement. The speakers are jbl d140f in Sunn cabinets. They used to sound great. Any help would be much appreciated.
    Novelist:
  • 153 Answers
Both of your problem amps were made in the '70's or earlier. It is entirely possible that the coupling capacitors are failing. This is an issue for a service center whether it is caps or something else, like failing tubes.
The good news is that installing metalized polypropelene capacitors will make those classic amps sound incredible.
Posted on Apr 24, 2009
Guitar is not working the directional buttons do what?
If you mean the lever switches on the guitar, they will allow you to choose which pickup is on, and this changes the tone, that is the treble and bass response, and so colours the sound.
Feb 18, 2014 | Activision Blizzard Guitar Hero 6:...
Tip
Home Studio Recording: Part 3
Once again, we dive into the subject of recording your band's (or your solo) album. So far, we've covered the basics, and how to record drums. Today, we talk about the all-important Bass Guitar.
There are a few different ways that you can do this, one being the industry studio standard of using a Direct In box, or DI. How this works is you run through this box, which then has two cables. One to the mixer, and one to your amp. You then mic the amp (see below for mic placement), and get both the clean and amped signals together on the track, giving you a fuller sound.
Method number 2 - Amp your bass, and add the effects there at the amp. Compression, chorus, and distortion are some popular ones with the bass guitar these days, even in country music. Light overdrive gives a bass more high end sparkle, making it easier to hear it at the lower volumes.
Method number 3, and suggested if you don't have a DI box as well as if you don't want to anger your neighbors, who bang on the ceiling with a broom (just joking on that. Still, don't tick them off!) - Plug your bass straight into the computer, and record two tracks simultaneously. On one of the tracks, apply an amp simulator with the desired effects. On the other, apply ONLY an equalizer and compressor, in that order. What this does is gives you the amp tone, as well as accentuates the lower frequencies of the bass guitar. It's the shortcut that actually produces great results.
For mic placement on your amp, you can use either a condenser mic (which requires a preamp, or a mixer with phantom power), or a dynamic mic. Both will give you a great sound, but it's up to you to find what fits your sound, and your budget.
Placing the mic. - Pick your best sounding speaker. To do this, turn your amp down, and play a note. Go to it, and listen to each speaker by placing your ear directly in front of it (this is why we said turn it down). If your best one is close to the floor, rotate the cab so that it's one of the top speakers. Using a standard mic stand, place the mic so that it's pointed directly at the speaker, but it's about 2 inches in front of the cone, and 2 inches to the side. You can experiment with different placements, such as directly in front, or to the side and pointed across the speaker, but this is usually the best sound you'll get.
That's all for this segment of Home Studio Recording. Join us later for part 4.
on Mar 27, 2011 | Music
Rms b80 bass guitar amp has little volume in the low side jack , hi side jack is fine just not as much bass
The low in side jack has a lower vol. but should only be1/4 less than the high in jack on most amps, --try this,-- plug guitar in high in then take all the treble off and 1/2 mid. range bring up bass range and if you have equauzation bring down 26k 5k 10k about 2 notches or points. See if that give you better bass tone.
Oct 10, 2013 | Bass New Rms 40 Watt Bass Guitar Amplifier
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
Bass strings are too loud in comparison to treble strings whe played through the amp
Adjust this using the EQ on the amp and to a lesser extent the tone controls on the guitar.
Often people boost the bass way up causing this problem.
Feb 12, 2011 | Epiphone Sheraton II Guitar Electric...
How to get a fat and clear sound from schecter
Ninety percent of what you want depends on the amp and speaker you are using.
You likely will want a 15 inch speaker in a bass cabinet to start with and a decent midrange driver as well.
No amount of EQ will fix an audio system that just can't put out the bass tones.
Nov 14, 2009 | Schecter Stiletto Deluxe-4 Bass
For 100 watts it doesn't seem that loud to me. Could I maybe add more speakers (2x10s)?
Our human perception of loudness can be way off. You should get a soundmeter and compare. There are some pretty good ones on eBay new for about $140.
Adding speakers may NOT increase the sound much as the power will then be split between the speakers.
Nov 02, 2009 | Fender Rumble 100 Bass Guitar Amplifier
How to get the best sound
punk and metal tones (late 80s): treb-7 mid-6-7 bass 6-8, presence 6-10, gain/distortion all the way up. classic rock just turn down the gain/distortion to 6-7. bridge pickup
metal mid 90s & up: treb 6-7, mids 3-5, bass 7-9, gain all the way up, presence (which is a mid and treble boost) 4-6. bridge pickup
blues SRV: treb 6, mid 6, bass 7.5, presence 8, gain 5, reverb (if you got it). use your neck pick up
of course this is subjective and depends on the guitar, cable quality, etc. it looks like a small speaker with a low watt output. that little speaker in there is going to be hard to articulate any tones. more than likely it will have a harsh bit to it cause the value of the pots and the logarythm you hear. reduce treble as needed to smooth out the harsh, keep the mids up.
Nov 02, 2009 | Washburn Amplifiers: 25 WATT Guitar...
Bass amp for guitar?
i say it can! u would get a nice clean sound! acoustic guitar sounds nice through a bass amp!
you probably wouldnt get distortion out of bass amp though! depends on the bass amp! some bass amps have built in effects! e.g distortion
Oct 15, 2007 | 3Com SuperStack II advanced RPS...
My amp makes a constant tone
its says 800 watt and you say 20 watt bass amp?? Is this for a car or a guitar??
May 24, 2006 | Pyle 800W GUITAR AMP Car Audio Amplifier
Computers & Internet Logo
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
