Keyboard not typing correct characters - Computers & Internet
  • sharmili Apr 01, 2009
    If the enter key is pressed there is some special character is displayed for each hit on enter...
Try the following...
-uninstall the driver
-unplug the keyboard
-reboot
-plug it back in and have it install itself
Posted on Nov 04, 2008
Keyboard not functioning
It may be a fault in the keyboard driver or in the keyboard itself. However if the character you need is not available on the keyboard directly it is possible to get any character by using the ASCII char code entry method. First off search the internet for a ASCII character number associating table (for a chart I like best, check here http://michaelgoerz.net/blog/2008/09/ascii-table/ascii.gif) now on this chart you have to use common fonts (IE: Ariel, times new roman, ect.) because some of the TTF fonts do not have all the characters in them available.
Now to practice using the characters, load Notepad and find the character you want to display from the chart (note: the number like 000d and 00h actually means 000 decimal and 00 hexadecimal, only use the number with the "d" after it with this method), on Notepad, after you pick out the character you want to display, press and hold the ALT key, and on your keypad (on most keyboards it is on the right side and resembles a calculator type keypad) while holding the ALT key down enter the number of the character you want to display (do not include the "d", only the number) then release the ALT key and that character should display for you in Notepad. Almost all standard fonts has the regular characters and some has the extended characters, you will have to check to see if the font uses them by trial and error. this method is a long lost forgotten means of putting characters into your documents which does not have keys on a standard keyboard (most standard keyboards only have 101 keys so this is the only way of using all the 255 character available in common fonts).
This is a built in function of all computers that uses Microsoft OS's and even DOS, HDOS, EDOS, (well all the DOS's), and you can use them anywhere you can type anything from your keyboard, (emails, letters, databases, spread sheets, etc.) if you can type from the keyboard to any program you can use these characters in this manner.
I hope this help you out!
Aug 15, 2013 | E-Machines eMachines Desktop PC
Tip
Some letter key is not working on keyboard???
if any of the key on the keyboard is not working, you can use an alternate for time being. This is regarding ASCII. There are ASCII codes for every character on the keyboard. A - 65,B - 66........... So on a - 97, b - 98...........So on
Use these codes by pressing and holding Alt key on the keyboard. In order to type b character. Press and hold Alt key and type 66 from the numpad at the right side of the keyboard.
on Apr 17, 2010 | Computers & Internet
My pound sign comes up as # and my @ as "
Windows 7 or Windows Vista
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, expand French (Canada).
  5. Expand Keyboard list, click to select the English(United States) check box, and then click OK.
  6. In the options, click View Layout to compare the layout with the actual keyboard.
  7. In the Default input language list, click English(United States) - English(United States), and then click OK two times.
  8. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  9. Click the Language bar, and then click English(United States).
Windows XP
  1. Click Start , type intl.cpl in the Run box, and then press ENTER.
  2. On the Languages tab, click Details.
  3. Under Installed services, click Add.
  4. In the Input language list, select the language that you want. For example, select French (Canada) .
  5. In the Keyboard layout/IME list, click English(United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
  7. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  8. Click the Language bar, and then click English(United States).
How to make sure that the selected layout matches the keyboard Windows 7 or Windows Vista
  1. Click Start, type osk in the Start Search box, and then press ENTER.
  2. Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
  3. To check the uppercase characters, click the shift key on the keyboard or on the screen, and match the characters printed on the keyboard.
Windows XP
  1. Click Start, type osk in the Run box, and then press ENTER.
Jan 07, 2011 | Dell Computers & Internet
What to do if dish soap bubbles got on the keys and certain keys type numbers as well?
Try the "On-Screen" keyboard to see if it types the correct characters and number. If it's ok, then get another keyboard.
Oct 31, 2010 | Computers & Internet
Automatic tyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyping of characters
That would be the best solution! Reason being that the serial port is not converting the info correctly reason why ur seeing that on the screen..also the board on the keyboard can not function in that type of transaction!
KJR
Jun 17, 2010 | Dell Dimension 2400 PC Desktop
Casio TK-2100 total reset and display name change
Hi.
Turn key to program mode.
2 SUBTOTAL
13 SUBTOTAL
Now type the characters for the first line of the receipt message using your programming sheet under the keyboard.
CASH
23 SUBTOTAL
Type characters for second line
CASH
33 SUBTOTAL
Type characters for third line
CASH
43 SUBTOTAL
Type characters for fourth line
CASH
SUBTOTAL
That should do it.
If you have trouble, just post me another question.
Mark
Dec 15, 2008 | Casio Parts Cash Register PC Desktop
Keyboard does not type correct keys as pressed
This sounds as though your keyboard mapping has changed.
What characters do you get?
First, can you plug in the keyboard to a different computer? Does this other computers keyboard act the same way when plugged into yours? If so, then it is a mapping issue. Their are several places that access the keyboard map.
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
387 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
