Question about Motion Computing M1300 Tablet PC
MOTION M1300 PROBLEM
My 1300 has been working perfectly. Trying to start the machine in the morning I found that it is impossible to do so.Operating the main power switch does'nt start the unit. Any suggestions ?
  • 4 more comments
  • nyonair Nov 04, 2008
    power adapter ok,unit charges battery.
    no change, battery charged. Still cannot switch unit on.
    battery at fully charged level.I have 2 power adapters,have tried both of them.Problem remains.
    unit does get power ! have plugged photon frame to same wall socket,no problem. tried 2 adaptors, no solution.battery has optical scale of charge, fully charged. Do power on switches ever fail
    have contacted Motion and been told that there is no tech.support in Europe. Got tel.number 866-566-7012 to ring for advise. Too expensive to call from here and skype does''nt work. Had US friend try to call.He gave up after numerous call without getting to speak to somebody
    did you redceive my last message re tech support ?
Your power button needs to be replaced !!!
hope this fixes your problem Good luck.
Posted on Nov 04, 2008
  • 6,487 Answers
If the unit wont even power ON with the battery of with a power adapter connected to it, the problem here can be a already a bad power supply of your tablet PC that may need a replacement already , because battery and ac adapter are fine so it just the power that is not getting inside your tablet PC...
  • Mark Gil
    Mark Gil Nov 04, 2008
    Yes this also sometimes a problem with the power switch if its already loose and when you press it it doesn't do any contact to the power supply, it will be better to try taking it apart if and check for any loose connection inside it before you decide to take it to a service center near you....
    Brigadier General:
  • 3,614 Answers
REMOVE THE UNIT BATTERY FOR A WHILE, PUT IT BACK AGIN AFTER YOU REMOVE. AND FULLY CHARGE AGAIN THE BATTERY.
  • 2 more comments
  • micromaster
    micromaster Nov 04, 2008
    you mean the unit never lights up, or it seem that it never got any power from the battery or into a adaptor?
  • micromaster
    is there any light on the panel LED states that it was ON, or CHARGING..?
    or no light on the LED at all?
  • micromaster
    this is a problem on the control board. pressing or pushing the power button the unit doesnt seem to respond. due to electrical surge, or overheating. it better to check and bring it on the authorized service center to avoid anymore damaged on some parts.
  • micromaster
    Andy Toal
    Motion Computing
    - UK
    44(0)2476311685
    email:
    atoal@motioncomputing.com
  • 905 Answers
Remove battery and power connector , then try to power up with just the power connector
if it still will not power up , did you leave the power connector plugged in during the night?
if so then the power connector needs to be checked for voltage output , if it has the voltage then the problem will be in the power input section of the pc
it is not likely that the power switch just quit over night but if the power was plugged in all night then the power souce could have quit or there is a component that quit inside of the pc
have you tried these to determine if there is power to the pc? do you have a volt meter to check for power output on the connector and the battery?
  • jason Nov 04, 2008
    can you tell us if it was in stby or was it shut off during the night?
    also was it plugged in all night?
    and if it charges the battery then that part of the circuit is ok but if it is just saying battery charging and actually not charging the battery , there is a problem with the power source or a component in the pc
    if there is a card plugged in take it out and see if it comes on
    but if it does charge the battery then the problem is in the pc and it will need to be tested to find what has failed
    Genius:
  • 2,035 Answers
Slide and hold the Power switch for at least a half-second, but no more than three seconds...If this did not work then Connect the AC adapter to operate the Tablet PC and charge the battery.
Good luck...
  • 1,879 Answers
Tried AC power adaptor?
  • chezulkhairi Nov 23, 2010
    got one m1300. it will only switch on if direct plug to wall. if plug to adapter extension etcs then to the wall, it will not switch on. ?? try that.
My motion computing battery light is not on and the machine won't start
Hold down the power button for 10 seconds then release. Then try pressing the power button again.
Apr 26, 2011 | Motion Computing J3400 Rugged Tablet PC...
Motion m1400 tablet pc reset bios
My m1400 Can't find operating system and I can't install another xp. It wont boot from my usb cd rom drive, What are my options?
Apr 14, 2011 | Motion Computing M1400 Tablet PC
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
Operating System Not Found
Hi and welcome to FixYa,
Almost always, your described problem indicates a hard disk problem: either it is no longer recognized (most likely) or the partition / files are corrupted.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Gateway M1200-3004265 Tablet PC
Have motion tablet pc 1600 , suddenly when starting up get "problem or unable to load operating system"
It could be one of several problems:
1. Bad hard drive (reasonable likely depending on age); does the hard drive make noise or spin?
2. Loose hard drive cable (less likely)
3. Virus (likely)
If it doesn't boot at all you can open up the back and make sure the hard drive is "seated" properly - that means all the connections are firmly in place. If that doesn't take care of it you will have to try and reinstall the OS.
John Hill
www.alltp.com
www.tabletpcbuzz.com
Mar 01, 2009 | Motion Computing LE1600 Tablet PC
Power port on le1600 does not charge batteries.
In some Motion LE1600 tablet pcs, the AC adapter port becomes separated from the motherboard. It will charge in the convertible keyboard or docking station because the power comes from the USB connection (for the kb) or the dock connector (for the FlexDock). Motion used to fix this by repairing the solder joint but now they just replace the motherboard (very expensive). There are ways to solder this but the repair doesn't always last unless you have someone really good do it.
Oct 24, 2008 | Motion Computing LE1600 Tablet PC
Motion m1200
First be sure that you are running windows XP tablet edition, then download the drivers from motion computing. This is the link:
http://www.motioncomputing.com/support/driver_download_1200.asp
If you are running windows XP regular not Tablet PC edition it is not going to work, toush pad and buttons only work on tablet edition.
This solve the problem.
Apr 24, 2008 | Gateway M1200-3004265 Tablet PC
Touch Screen won't work on Windows
Is it running Windows TabletPC operating system? This version of the OS includes support for the touch screen.
There is also a known Microsoft problem that this might be related to. You can check out this link for more information: http://support.microsoft.com/kb/914444/en-us
BTW, Microsoft does not charge for calling to get a hotfix like the one listed in this article.
Feb 11, 2008 | Samsung Q1 Tablet PC
Motion Computing M1300 Tablet PC Logo
269 people viewed this question
Top Motion Computing Tablets & eReaders Experts
jason
Chris Larocque
dante
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
