Question about Panasonic PT-47WX51 47" Rear Projection Television
The picture is off vertically. There is a black stripe at the top of the screen. The picture runs off bottom of screen so you can't read the taglines at bottom of screen in news reports and such. Is there any way to adjust vertical screen on this model? I know my TV repairman went into service mode to try and fix it at one point, but he couldn't figure it out. Can it be done in repair mode? And if so how do you get in and what do you do? Thanks and hope to hear from someone
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directipicture off on screen vertically-Black at top of s - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem. Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
picture off on screen vertically-Black at top of s - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
Sep 03, 2014 | Televison & Video
Nov 09, 2013 | Cars & Trucks
Nov 05, 2011 | Symphonic ST419E TV
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Jun 02, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Dec 22, 2008 | 1995 Ford Windstar
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
Feb 28, 2007 | Beko 324250WN 28" TV
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
54 people viewed this question
