Question about Maytag MSD2656G Side by Side Refrigerator
Side by side won't get cold
Fridge does not get cold...seems like it is pretty dirty...could NO COLD be due to dirt?
    President:
  • 1,462 Answers
Not usually - mine is filthy! is compressor running?
Posted on Nov 04, 2008
Samsung side-by-side , freezer fine, top half of fridge won't stay cold, temp goes to the 60s. The drawers seem fine. The compressor is pretty hot. Any ideas?
You are probably experiencing a defrost problem. if you the back wall of the freezer closely, you are like to discover frost buildup which stops the flow of cold air from the freezer into the refrigerator. In a "frost free" unit, the defrost heater comes on every 8-12 hours to remove the frost. if the defrost fails due to a bad defrost timer, or heater or thermostat, the refrigerator will malfunction and ultimately the freezer will too.
I am not sure you can solve the problem on your own wiothout the proper tools and familiarity with the equipment.
Jun 29, 2014 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Samsung side by side refrigerator RS265TDRS started making loud propeller like noise on the cooler side half way up. Notice bunch of ice around the lights on the back wall of it. I unplugged the fridge for...
A COUPLE THINGS U SAY FREEZER IS FINE FRIDGE IS NOT? THE FAN NOISE MAY BE DUE TO ICE BUILD UP DUE TO A DEFECTIVE BAD DEFROST TERMINATOR. WHICH EVENTUALLY WILL BUILD ICE UP IN FREEZER AND FRIDGE? HINDER COLD AIR CIRCULATION. ANOTHER THING TO LOOK AT IS UR FREEZER AND FRIDGE THERMISTORS AND UR COLD CONTROL THERMOSTAT. EVEN UR AIR FLOW DAMPER CONTROL VENT AND KNOB SETTINGS? ARE THEY TO FAR OPEN OR CLOSED? ARE U ABLE TO HEAR THE FAN AND COMPRESSOR RUNNING? ANY CLICKING SOUNDS?
Feb 25, 2012 | Samsung RS265TDRS Side by Side...
Maytag side-by-side (MSD27 series) refridge is a superb unit, tremendous common-sense quality features -- BUT it just started running ALL the time, after major electrical storm. Freezer and fridge side...
Sounds like u need to clean the condenser coils behind the access panel in the back. When too much lint or dirt builds up it causes the unit to run inefficiently. If that doesn't improve things then it's possible that ur compressor is going bad and not working to it's fullest capabilities and it's about tk go bad. Maytag usually has an extended parts warranty on their compressor so check ur manual to see how long it's covered. A tech can do an amp draw on the compressor to verify if it's running to hard due to a bad winding.
Jul 06, 2011 | Maytag MSD2756G Side by Side Refrigerator
Fridge side warm freezer still seems okay
frig side is warm due too no cold or air getting to fresh food side . i would ck for ice on the cold coil in freezer . this is most common .. mm
Oct 22, 2010 | Maytag MZD2766GES Side by Side...
Door gets warm
Warm is normal hot is not. Too hot is an indication that the condenser coils are overheating due to being dirty or a bad fan motor. See the link below for details I put together on this. Let me know if it helps.
Hot Condenser
Jun 03, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Fridge side works, but the freezer doesn't
Hi, there is a common fault with these side by side models, the electronics fail in many ways. The first sign of failure is either due to the compressor not working or the 'evaporator' (the cold bit) ices up and air can't pass through it to cool the freezer and fridge.
You can buy a kit to repair the boards for about £30 on ebay
Look for Whirlpool repair
An engineer would charge £200 +
Hope this helps
regards
j
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer not cold enough
I believe that it is low on freon due to a leak or is dirty underneath and has to be cleaned where the condenser coils are.  If they are dirty it can't disapate the heat that its pulled out of the inside of the unit so it acts like its not working.  That would be the 1st thing to do is to clean the coils it should make a difference in an hour.  If not then you must have a leak in the line somewhere, which would cause the coils to frost up also.  If the large line coming from the compressor has frost on it then it is a leak.  Needs to be repaired with a repairman.  If anything else we can help with let us know.  Thankyou for your question
Mar 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Sep 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
69 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
