Question about Toshiba TP55G60 55" Rear Projection Television
Low sound Hi, i'm trying to fix my Toshiba pro, my problem is that the vol: is very low even if the control is set at high. Is it the EEPROM ???
  • Hollis Williams Oct 05, 2006
    Hi jomaru, thank you for trying to help me. Yes i did checked for cold solder jions, i even changed the sound IC: i used to WORK for Sharp and RCA, COMPANY ......i got this tv from a friend, and i will like keep it.if you think about any other thing let me know. I also use the video in an the vol: still low.
    Thank you.
    Hi jomaru, thank you for trying to help me. Yes i did checked for cold solder joints, i even changed the sound IC: i used to WORK for Sharp and RCA, COMPANY ......i got this tv from a friend, and i will like keep it.if you think about any other thing let me know. I also use the video in an the vol: still low.
    Thank you.
    Sergeant:
  • 337 Answers
Your set should have a separete stereo amplifier board ,follow the wires from the speakers and it should take you to it,tap on this board and see if the sound changes if not try taping on the main board,dont over do it and do not use anything metal use the plastic handle of a screwdriver,it should not take too much to make it react then you know you have a loose conection,if you are familiar with tv service this should help but if you are not too familiar be safe and call for help.If you dont have loose conections at the audio output the voltages will have to be checked.
Posted on Oct 04, 2006
  • Omar Urrutia
    Omar Urrutia Oct 06, 2006
    You are going to need the squematic to troubleshoot thsi problem,need to check the voltage change from the VOL.UP button to whatever pin in the microprocessor and also the voltage change at the audio output from the micro.Let us know what you find.
SOURCE:
Toshiba A210 builtin speakers volume is full but sound is very low.any online solution?
goto control panel the select the sound icon and u can see the adjustment there or at you desktop you can see the right panel if you can i see the speaker double click it and adjust to make your sound high..
Mar 09, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Problem with the Toshiba Satellite Pro L300-25L display
it sounds as if your screen resolution is set too high, or you have a low colour. right click on ur desktop and click properties then click settings, make sure your colour quality is "highest 32 bit" try sliding the resolution slider across to try the diffrent settinfs to see if it gets better.
Jul 02, 2009 | Computers & Internet
I own a Toshiba TW56F80 rear projection unit. I've owned it since 1997, and it has served me well. A few months ago, I heard a zap sound from inside the cabinet, and all my remote functions stopped. I can...
Sounds like to me that a HV Arc or a Static discharge has corrupted the eeprom data or caused the Main Micro Processor to lock out those features. Have you unplugged the set for 24hrs? As easy as this sounds it is true that allowing the lower voltages bleed off so the eeprom and micro are able to fully re-set themselves. I doesn't always work but if you have not tried it, try it . That would be a cheap fix. If this does not fix it, parts are going to be tough to get because of the age of the unit. Toshiba may not even manufacture them any more.
Good Luck,
Skyassoc
Jun 22, 2009 | Televison & Video
JVC th-m505 and dish network box sound level control problem
It's not your receiver, it's the Dish Network equipment, I have the same issue with my Onkyo...unfortunately I'm still researching the solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/deric_c8d727d0b065baea
Oct 30, 2008 | JVC TH-M505 System
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
Sound
turn it up in master menu sound in control panel try nice set extrnals turn meadia player master vol up
Jan 19, 2008 | Compaq Presario M2000 Notebook
SOND FAILURE
open the sound device window in xp..by clicking on .... start/control panel/sound ,speech and audio devices/sounds and audio devices/......make sure firstly in the volume tab that vol is not set to mute or at a very low level ( i usually set it at max of 7) then click on advanced box and once again make sure none of the settings are set to mute. or very low ..you can fine tune these settings later if you wish...if you click on the advanced box within the far left master volume area then have the tick on in the s/pdif box....see hoe this goes and let me know
Jan 04, 2008 | Toshiba Satellite A105 Notebook
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
Service menu
Have you tried replacing the EEPROM? It may have lost it's programming for that set. Stargazer
Apr 19, 2007 | Proscan PS36123 TV
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Televison & Video Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
