Question about Konica Minolta DiMAGE Z1 Digital Camera
Replace Battery Cover
I bought a replacement battery cover and I am looking for instructions on how to install. The obvious 2 screws that looked like they held the hinge cover released nothing.
  • jngan Apr 17, 2008
    I have the same problem with my Dimage Z1 battery door broken latch-tabs ... but can't find where I can order a replacement door. Also, after reading the lengthy routine to replace the door, perhaps it's not worth the time repairing the broken door ... a new piece of rubber band seem to do the trick.
  • Kelbel108 Apr 18, 2008
    Where can you get a replacement battery door??
    Problem Solver:
  • 6 Answers
To get to the battery door you must remove the back, to remove the back you must remove the top of the grip (shutter button and dial and WT lever). remove top of grip... 1) starting at the bottom of the plastic strip (along the front edge of the grip) that holds the shutter button, slide upward, the strip will bow outward and after about 3/16", the bottom's free. the only other thing holding it in place is a bit of double-stick tape and a similar clip at the top. CAREFUL! there's a spring under the button that's easy to lose. 2) Inside the battery case, front battery, all the way at the top, there's a tiny phillips screw, pull it. 3) peel away the right side rubber grip right by where your thumb meets the W on the W/T lever. 1st hole you'll see is a springy clip, keep going around to the right til you find a screw. pull that. 4) back to the springy clip hole, pushing inward on the finger, the top will come off straight up. leave it hanging, you just need it out of the way so the back can come loose. remove the back... 5) bottom of camera, remove 2 screws nearest the CE label and one outboard of the rearmost battery. 6) viewfinder cap: 4 screws, skinny on top, fatter on the bottom. the cap pops off. 7) lcd cover/frame: pull away from viewfinder(top) edge about 1/4 inch. the bottom's held by fingers; they need to slide to the left 1/8", then that's off. 8) remove screw @ lowerleft of lcd. now the whole back will slide rearward. 1st thing loose is memory door, remove it. slide the back off, out of the way. you'll now see that the battery door is held on by two hinge pins, not one continuous. the rearmost pin will slide left into the memory cover area, and the door will flex enough to remove it toward the front. trickiest part of reassembly is the spring under the shutter button. balance the spring on the camera, put the button into place. hold it in place with the screwdriver through eye of plastic strip, leaves plenty of room to seat the strip. lose a screw? I did, and the least-needed one is the one pulled at #3.
Posted on Mar 26, 2008
How to replace Canon powershot sx150is internal battery
Hi! Doesn't the instruction supplied with the camera has this information? Anyway you can try to find it here Canon Digital camera user guides and owners manual
Just choose the needed model.
Mar 27, 2014 | Canon PowerShot Cameras
Installing new battery
Turn the calculator over. Look for some small screws that fasten a 1 or cover to the body of the calculator. Loosen the screws and remove cover. You should find button cell batteries. Before removing them make a note of the sign you see on the batteries (+ or -) while they still in place. Replace the batteries with the same model or equivalent ones. Replace the cover.
For more detailed instructions consult your calculator's manual.
Jan 09, 2014 | Casio MS-80TV Scientific Calculator
I JUST bought the coleman mini led headlamp and i don't know how the batteries are supposed to go in. the back will not open and there were NO instructions.
TO INSTALL OR REPLACE BATTERIES
1. Rotate body of headlamp until lights are pointing down and battery cover tab is to the front.
2. Insert edge of buckle on headband or a coin under tab and twist to unlock and remove battery cover.
3. Install 3 "AAA" cell batteries in the correct orientation as shown on the battery housing. Make certain all 3 batteries are installed
correctly.
4. Replace battery cover by first inserting the tabs on the back of the battery cover under the back edge of the battery housing, and
then rotate down until battery cover snaps into locked position.
For the manual: http://www.coleman.com/coleman/images/pdf/4343-704.pdf
Feb 21, 2011 | Coleman 3AAA LED Headlamp
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
I am upgrading the RAM on my ACER Aspire 5100 notebook to 4 Gig. I can't find clear direction to access the chips. The example I have seen has a small access panel in the center. My access panel is much...
This Graphical presentation is the rare view (backside) of your Acer Aspire 5100 pc,viewer?pid=bl&srcid=adgeesghtatd7i6f_banth1ziujysmb6ya1ewer4uybm-fgljto0nn5tiza-h7dnbazcojoyxa31-v5izh7bbtzocsfbua3xh_inrlmdybrlgesofu55eahbzbcvrkq_voq3zhus4ifa&q=cache%3adlx7k2i7jl4j%3asupport.acer.com%2facerpanam%2fmanuals%2facer%2f0000%2fuserguides%2fas5110_5100_3100-eng-olm_0425.pdf%20acer%20aspire%205100%20pc%20notebook%20how%20to%20upgrade%20memory&docid=51644d471099e93a540f8190a8866dcc&a=bi&pagenumber=33&w=800 Refer to the specs, number 2 is the memory compartment, you only need to remove the screws which are intact with the particular cover. If you can do it by yourself, you can refer to this manual, Page 19. Manual Good luck..
May 17, 2010 | Acer Aspire 5100 Notebook
Phone is dead, battery fully charged. Need instructions on how to disassemble the phone to look for obvious problems.
From the back of the phone, remove 1 screw @ the top/center. Take the battery cover off, remove the battery. Remove 4 screws. With a medium size blade
screwdriver, gently pry the case apart at the battery charger hole. Just pry the plastic, not the connector case. Then with a very thin precision blade screwdriver, work your way around both sides of the case. Note: there is a connector that goes to the display portion of the phone. Once the case is open, gently pry the connector of the main circuit board. There will be a keyboard cover, 2 side button plastic pieces, 2 side button circuit boards, the top plastic cover, and the bottom main circuit board.
Good Luck
Russ
Jul 13, 2009 | LG VX5400 Cellular Phone
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
I have acer 5315 aspire laptop,i have bought ram for it,want to know how to install
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover. Looks like this:
2 (a) remove the current memory by spreading the clips in either side of the stick, and gently pull it out (carefull with the clips, as they can easily break)
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size
Apr 02, 2008 | Computers & Internet
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Dec 05, 2006 | Kodak EasyShare CX7430 Digital Camera
Konica Minolta DiMAGE Z1 Digital Camera Logo
1,380 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
