Question about Canon MX700 Office All-In-One InkJet Printer
I need to dial zero before i get dial tone cannon MX700 cant send fax ???
How do i send fax through a swich board
  • Anonymous Mar 19, 2014
    When I send a fax the date says 2010
  • 417 Answers
You can set dial preferences in fax options using the 0 for the switchboard.
Posted on Nov 04, 2008
Cant send fax
Check whether you have dial tone by pressing [hook], if no tone, could be the fax card/PCB needs to be replaced.
Mar 31, 2014 | Brother IntelliFAX 4100 Laser Fax
L220 Cannon Fax tx function was not completed
It's possible you're not dialing the country's calling code or not dialing the correct sequence for international calling. To place a call out of the U.S. dial: "011 - country code - city code - number" The country code for Poland is 48. The link below contains the city codes for Poland which you may not have. Best of luck and I hope this solves your problem. Thank you for using Fixya and please remember to return to rate this answer.
International Calling Codes
Nov 26, 2009 | Canon ImageRunner 2020i Copier
When trying to send a fax, the fax didn't go through, could it be that i am doing something wrong, or possibly a problem on the recieving end?
Could be either, make sure you are set up for the proper dialing mode, either tone or pulse dialing, and check your sent fax report for the error code created when the faxes don't go thru, and let me know what the error # is.
Sep 03, 2009 | Canon MX700 Office All-In-One InkJet...
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Fax dial tone volume
Hi!
If there an kind of button of volume then u can...
otherwise u can't..
Amit
Feb 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon Image Runner 1023iF will not send or re: a fax
First try to check your fax settings.Your 'line settings' has to be set to 'tone' and not "pulse".
Set your fax mode for "fax only"
And try again.
Jan 20, 2009 | Canon imageRUNNER 1023iF Black and White...
No dial tone when sending fax
PLESE CHECK TO SEE IF YOU HAVE DIAL TON TO ANOTHER PHONE, OTHERWISE THE PHONE BOARD CALL THE NCU BOARD MAY BE BAD
Jan 06, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Mx700 fax connection problems
I can not received fax from my mx 700 when why answering machine is on.
Aug 31, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Pixma mx700 fax will not work when hooked up to answering machine
check for dial tone on your fax,and check to see if your fax telephone line is plugged into the "L" and not telephone. the L or line is the correct way. alsois it when you are trying to send or recieve.
Thank You,
Mikey
Apr 04, 2008 | Office Equipment & Supplies
Canon MX700 Office All-In-One InkJet Printer Logo
110 people viewed this question
old marine
old marine
