Question about Electronics - Others
Transcend USB not detected by Win Xp
I had formatted my transcend 2gb pen drive, using Win Xp SP2, and later saved few data on it. after few minutes i used the drive (on same PC), the system could not read the drive, but an icon does apprears on the systray. ow on my pen drive is undetected on all pc's i have checked. Even the CMD is showing 'Drive is not ready'. Is it possble to access my pendrive on DOS, or any software is available for that.Please let me know. Someone told me to use GDB fr that, but it doesn't shows my drive.Please help .
Well kaushal, it seems that the windows utility programs on ur pendrive has been corrupted thats why u r nt ablr to use it on any pc....
in this case u can do only one thing, try to connect ur pendrive in a pc running on a LINUX based PC.
coz LINUX does'nt require the windows utility programes... this is the only way out.
i hv also done it in past
Posted on Nov 07, 2008
I could n't access my files in my pendrive JF V30
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Sep 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive Shows Write Protected
These are the tech specifications of your pen drive which includes write protection micro S/D switch. So search it and make it read and write
USB 1.1 compliant and 2.0 compatible,
True Plug and Play for hot swap function
Maximum Transfer speed of 1.5MB (12M bit) per second at full speed
Powered directly via the USB port.
No external power or battery needed.
Operating Systems Supported: No driver required for Windows Me/2000/XP, Mac OS 9.0 or later, or Linux kernel 2.4 or later.Only Windows 98SE needs the provided drive
Write-Protect Function: Write-protect switch Security Function: Password protection available via supplied software (Windows environment only) Boot-Up
Function: Makes JetFlash a MS-DOS Boot Disk LED: Flashing LED indicates
Data Traffic Specifications : Size: 75mm X 11mm X 25mm (L x W x H)
Weight: 15g Data Retention: Up to 10 years Shock Resistance: 1000G (maximum) Erase Cycles: 1,000,000 times Speed: Read 9.0 Mbyte/s, Write 8.0 Mbyte/s (Max.) Certificate: FCC, CE,
BSMI System Requirements: Win 98/98SE/ME/2000/XP, Linux Kernel 2.4 and above, Mac OS 8.6 or later
Aug 12, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Transcend 4gb pendrive not being detected in Win XP
Hi... Try this link. It may work. Iam busy a bit. So cant go thru ur problem thoroughly. If doesnt work, post back. http://www.usbman.com/Troubleshooter%20General.htm
Nov 13, 2008 | Transcend (589307) Media
Transcend 4gb pen drive not getting detected
pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
Jul 23, 2008 | Transcend (589307) Media
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Sep 18, 2007 | Transcend (589307) Media
Electronics - Others Logo
247 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
