Question about Whirlpool Refrigerators
Whirlpool model # ET8TWK/ET8WTM with freezer on top. Everything in fridege is frozen even though I keep turning the dial lower. It's almost in the off position and stuff is still frozen.
  • 1073 Answers
SOURCE: fridge problem
you have a defrostion issue reed to remove the back panel in the freezer behind this panel is the evaperator coil needs to be melted down because it is full of ice and frost, ahair drier will work well,put several towells down under the bottom of the evaperator to catch water runoff, after defrosting the coil inspect the defrost heater or heaters some of these can have one or two heaters the heaters are located behind metal gaurds in the evaperator if either of the heaters are bad (both)need to be replaced, if they show good then bad defrost timer or bad defrost termination thermastat wiring diagram behind frount bottom grill
Posted on Apr 12, 2008
  • 828 Answers
SOURCE: Refridgerator temperature
I think it may be a defrost system problem. If you have frost on the back wall the problem is related to the defrost timer or defrost heaters or thermostat.
Also check the condenser for dust. If plugged with dust the system can not get rid of the heat. If dust is present clean it out completely.
Remove the toe plate under the refrigerator door to check the condenser.
Posted on May 24, 2008
  • 868 Answers
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
  • 635 Answers
SOURCE: the stuff in my freezer keeps starting to melt.
Either Your defrost timer is failing and providing a longer than usual defrost time or your startup capacitor is overheating and tripping, slowing down the time you resume cooling after a defrost. Neither part is very expensive and both are fairly easy to replace.
Posted on Mar 13, 2010
  • 43501 Answers
SOURCE: My fridge is not very cold.
There are a few reasons why the refrigerator part will not are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Posted on May 06, 2010
How do I turn on the lower ice maker on my french door samsung frideg,model # RFG29THDRS/aa
Make sure the bar that comes from the top of the ice maker is down. The bar is hit & raised when you open & close the freezer.
Jan 28, 2015 | Samsung Refrigerators
We have a Whirlpool with the freezer on top. The freezer is around 5 degrees, but the refrig. won't go below 47 even at the coldest setting. We vacuumed all of the vents and tubes in the lower front
The fan in the freezer may have stopped working. Or it could be the defrost drain tube is stopped up. Remove the rear plate in the freezer to expose the fan motor. With the rear cover off You can see if the freezer box has frozen over the drain. If so unplug refrigerator use a hair dryer to melt the ice. Keep heating the drain area until water runs down through the drain. Fan motors are available by model number on line or at local appliance stores.
Dec 30, 2013 | Whirlpool Refrigerators
Freezer is to cold and refrigerator not cold enough. When you open freeze it is always running
Sounds like the fan that cools the lower refrigerator is inoperative or it's fan blades frozen up.
Try defrosting. You will have to remove everything and remove the access panel to the fan to ensure it's fan blades are free and not frozen up. They have a built in inherent safety feature and sometimes they will work properly again when thawed out. More than likely the small fan motor burned out and will need to be replaced. There are appliance parts stores every were or call the mfgr parts department.
Once replaced your can restore your freezer setting to where it belongs. There is a dial that raises and lowers this setting.
The small fan draws air from the freezer and cools the refridgerator. It is also on a thermostat and usually has a dial to set the way it cycles and determines the temperature.
Jun 02, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Hi, my Whirlpool fridge is not cold even though I had turned it up to 3/4 of the cold dial. Ice does not form in the top compartment.
If there is no frost on the rear wall inside the freezer and the fan in the freezer is working , pull the refrig out and feel if the compressor is running . If not running , tap on the temp dial , firmly , and see if the compressor starts . If it does , replace the thermostat ( part behind the dial ) . If it does not start , replace the overload/relay , which is plugged onto the side of the compressor , with 2 or 3 wires going to it . If the compressor IS running , remove the inside freezer panel ( remove the ice maker if it has one ) and see if the coils are frosted . If so , then you have a defrost problem , which will be a different set of instructions .
Sep 26, 2010 | Whirlpool Refrigerators
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Hi, I've got a candy fridge/freezer combi. (bottom freezer) It's a futura CFMF 236a. Fridge compartment is freezing everything. got solid milk, solid drinks and frozen food. When the fan cuts in it just...
The super is for super cold and on that setting it might not cut off. If it's not on that setting then that control is probably bad.
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
Feb 10, 2010 | Refrigerators
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
Has just one termostat on bottom, freezer won't keep ice cream frozen, although it does keep meat and ice froze
OK send me the model number as found in photo below. You may have a circulation problem that I will be able to look over closer when I have model number. Sea Breeze
May 25, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge frozen solid
Usually on refrigerators, the highest setting makes it coldest and the lower settings are warmer, relatively. "6" on my dial says "coldest" - Perhaps this is the case for yours? Let's hope it is that simple
Aug 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
131 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
