Question about Neff 24 in. S5456 Built-in Dishwasher
Pum continue running and never end cycle
Congatulations for your web site, I wish We have one like this in France. Like a lot of message there I have a problem with my Neff S5456 dishwasher. At end of cycle the pump continue to run ever and ever. I have checked the read floater on the left side of the dishwasher, it seems not to work, I cleaned it with vinegar then I was working propoerly but still have my problem. I have read that it may be also the water detector not working. Have someone get an idea to help
  • wil hinde Nov 30, 2008
    Yes i have the same issue at 53 mins from the cycle end the machine has stuck in the pump phase. Is there a way to refresh the program. I have tried the re-set buttons & it tells me to start a new cycle but the pump is still running. Any ideas
Ok,
So you know how to get to the float mechanism. I also noticed that when i lifted the red anti flood pole the pump keeps going & also the float will not move because if you add water to the small chambe it runs away as it should do. The next thing i tried was to unplug the electronic float switch. I use alot of these devices in my line of work & sometimes they stick. By unpluging it & seemed to do the trick once reinserted the pump has stopped. To double check just lift the red pole & the pump will start again as if it has registered a flood alert. Problem solved & £300 better off. Note if it still runs after this, the switch could be at fault they cost pennies to replace. Good luck
Posted on Dec 07, 2008
My magnavox tv cycles on and off continuous. Never stay on or off.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 16, 2015 | Televison & Video
How do I remove 502 Bad Gateway from my computer
Generally, a 502 error is not something you can fix. It means that one or more of the servers that fulfill your request for a web page aren't sending back what's expected. (It's quite typical for a web site to grab data from other places to render the page you are looking at. The main text usually comes from the site you are looking at, but a lot of the times, the pictures, video, comments section, etc., might be hosted on another machine altogether. The ads placed on web pages typically come from outside servers.)
If this is the only web site on which you are getting a 502 error, it probably is the site. However, I was able to go to http://www.quotev.com/ (using FIrefox 19.0.2 and Chrome Version 25.0.1364.172 m) with no issues, which makes me wonder. If you are getting the error when visiting a lot of sites, it's probably time to do some more digging on your end. Have you tried power cycling the router that serves the Internet at your place? It's possible that the site has moved to a new server and the router has some of the old web site IPs in it's routing table. That is, it might not be your laptop, but in the router or further upstream toward the web site.
Jul 02, 2014 | Computers & Internet
Car starts but only runs smooth when not giving much gas then it dies alot while driving to get it to start i have to cycle the key switch unyill i hear the fuel pum bild up preasure
that's would be the fuel pump dying slowly, you should replace it before it leaves you stranded some place. If you wish to do this on your own please message me back and i will give you detailed instructions on how to preform this operation on the 97' Chevy Cavalier.
Jun 09, 2011 | 1997 Chevrolet Cavalier
After the defrost cycle ends the evaporater fan doesn't start on its own. You need to hand start it, then it continues to run till the next cycle
most refrigerators do not start the evaporator fan at the end of the defrost cycle. If it did it would blow a lot of heat thru out the freezer compartment. The coil has a fan delay to start the refrigeration then when the coil gets cold enought the fan comes on. If the is not what is happening, replace the fan motor. thanks
Apr 22, 2011 | Kenmore Side by Side Refrigerator
I would like to know how to run a cleaning cycle on a Kenmore model 09/06 # 970-C45192-30 . Thank you.
Would a manual help. particularly in the future with problems?
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
If this has assisted you please score accordingly.
Thanks and good luck!
John C.
Apr 11, 2011 | Washing Machines
Good morning I search a front right suspension arm for my 1969 Plymouth Valiant V100. Here in France the mechanic said that the mechanical part doesn't exist anymore and that it should completely...
Sorry but i think hes right ,look on some american web sites for classic parts but if no joy then ask mechanic to have a new ball joint fitted as you have the same vehicle inspection in france as the rest of europe ,its a europeon standard so if you cannot find a new one on a american web site for voitures then yes rebuild it like i had to on a daihatsu for a customer
Sep 11, 2010 | 1983 Plymouth Reliant
IT STARTS TO FILL BUT THEN STOPS, DOES NOT DO WASH CYCLE dwd4310w dishwasher
You have to check the water flow from the pum end. the spray arm rotates under water pressure only. Try cleaning the hose if possible from front. Clean the rotating arm also. jet holes
Apr 11, 2010 | Dishwashers
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
Yahoo chat
  1. The Web Page that you are trying to reach might be out of service. Try visiting different Web sites to see if this message still displays from other sites. If visiting other sites also cause the message, continue using these steps.
  2. If you are using IE 7, reset Internet Explorer 7 settings and try again. If the page display problems persist, continue.
  3. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 softpub.dll In Windows XP , click Start , and then Run enter the following into the open field: regsvr32 softpub.dll
  4. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 urlmon.dll In Windows XP, click Start , and then Run enter the following into the open field: regsvr32 urlmon.dll
  5. Restart the computer and then try browsing the Internet again. If the page display problems persist, continue.
  6. Open Internet Explorer and click Tools , and then Internet Options .
  7. Click the Programs tab, and then click Reset Web Settings .
Sep 23, 2007 | Computers & Internet
Neff 24 in. S5456 Built-in Dishwasher Logo
331 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
