Question about Olympus Camedia C-900 Digital Camera
Battery Drain Hi The camera has started to kill batteries while switched off. About 10ma being drawn with the front shut.
If I leave pickup 8 hours, why is it dead and has to be jump started?
Sounds as if there is a parasitic draw on the battery. You need to perform a draw test to see what amperage is being drawn from the battery while the vehicle sits. Anything more than !/4 amp will kill the battery overnight. Check for any lights that may be staying on inside the vehicle as well as outside the vehicle while it is shut off before getting involved in a draw test
Feb 20, 2016 | 2005 Ford F-150
The battery is easily drain even i replaced it an new battery, what is the posible problem of my vespa lx 150 ie? Ty
Many answers you need a multimeter or ammeter to measure the quiescent current drawn (power used when nothing turned on)
Set it on the 10a scale and measure the current drawn ,put the leads in series with the battery feed wire.
Causes could be a faulty regulator pack or a short on the stator of the generator,a scuffed cable shorting to earth ,(usually around the brake light switch) or a faulty switch causing a lamp to light continuously . I could go on but that should give you a starting point.
good luck
Nov 12, 2015 | Vespa Motorcycles
2006 liberty new battery alternator works when sets over night battery goes dead put a kill switch on and still goes dead ?
put kill where? at battery post, and is just a switch,
not those dynamic battery drop relays?
if the battery goes dead with the neg. lug pulled the battery is bad.
end of life , battery.
the lug pull never lies.... ever.
if stays ok now this is called battery phantom drain.
(or aka. dark currents)
finding cause takes an ammeter. any,
here is all ways to find a drain.
http://www.fixkick.com/drain/drain.html
Mar 03, 2015 | 2006 Jeep Liberty
Hello Jr, The fact that the battery goes dead even with a kill switch would lead me to think the new battery is defective.
Kawasaki vulcan 900
kill switch on will not discharge a battery unless ignition is on at same time , check earth cable to motor and to starter switch
Mar 09, 2014 | Motorcycles
What is wrong with my 2003 BMW 525i?Battery Drain
excessive power loss due to alternator bad..take to parts store so they can check it..diode trio is bad letting power back thru the alternator..basically it wont shut off now and will kill the battery after several hours..
Dec 26, 2013 | BMW X5 Series Cars & Trucks
Leave honda crv 2003 in parking lot while on vacation (7 days) come back car won't start I mean nothing, need to jump start and it's okay, Happened twice I left with everything off and shut with...
not really, except unhook the battery. there are several things constantly running all the time. 'clock,computer, etc. eventially, the battery will drain. then again, your battery may be weak. an auto parts store will test it for free.
Sep 15, 2011 | 2003 Honda CR-V
Seat Cordoba Electrical Problem
either fit battery cut off switch or try taking the wires off the back of the alternator ,i have a funny feeling its a diode packed up in the rectifier
May 31, 2010 | Volkswagen Jetta Cars & Trucks
Cigarette port
All newer vehicles have a safety battery shut off. Youll need to turn your key back to accessory. say your listening to your radio with the keys out, it will shut off after 10 mins so it dont drain your battery. dont worry about it killing your battery charging a phone...ect.
Feb 21, 2009 | 2003 Cadillac CTS
Flat battery
Replace that fuse and start by removing fuses one by one from block, till draw disappears. Then, check that system for problems.
Don't forget: your alternator will always show up as a small draw.
Check accessories such as glovebox light first... Often, if box is not closing properly, it will kill the battery in a few days. Same goes for interior light delay!
Dec 26, 2008 | 1996 Jeep Grand Cherokee
Cameras Logo
41 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
