Question about Samsung HCL473W 47" Rear Projection Television
Bluring colors - three dimentional type picture image
I beleieve I have the same problem started on my TV last week. I called on a technician and after checking he told me that one of the card ( board ) need to be changed. the second one told me that they wil change two ICs and it will be fiixed. I know that I am technical enogh to chnage the board if I can find it from internet. Pls help me!!!! .. guide me to the solution...after reading on the net it seemd to be a comman problem on this model....Is this sounds same thing as convergence problem....I believe its the same thing. Your early response will be approciated. Beeju.
  • proline69 Apr 26, 2008
    hi ,I have the same problem with my t.v with the 3 dimentional type picture and bluring colors.Is this going to be expensive to fix .please let me know .
  • JohnTVman May 11, 2010
    I replaced the convergence ICS & the red is off
Go to www.samsungparts.com for parts for your set.
Posted on Dec 09, 2007
SOURCE:
SERVICE MODE TV LCD TOSHIBA 19HV15E
1/3 layar ada garis2 vertikal,apanya yg rusak
Apr 19, 2013 | Toshiba 19HV15 19" Multi System LED TV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Bluring of colors
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2010 | Philips 55PW9363 55" Rear Projection...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
Can bad color wheel cause lamp to not turn on
Actually yes, the thing is that the color wheel is also part opf the light engine system and if it's not working, it will prevent you to see an image, you will need to replace it and it's most probable to fix your issue, of course since it's a Samsunt Tv, you need to identify the type of color wheel that you have, it could either be one with a gold bearing or one with a silver bearing, just identify which one is the one you have, and you'll be goo to go
Jul 24, 2009 | Samsung Televison & Video
Spots on picture screen,color not correct
the picture tube has three color production units (bulbs) red, yellow and blue.....since these three colors can be combined to produce almost any color. as you have specified the red bulb might have damaged due to one of the following reasons.
1.continuous usage
2. keeping your tv in standby mode for a prolonged time.
the only thing you can do is call a technician and get your damaged part replaced.
remember please do not try to disassemble the unit yourself.
May 28, 2009 | Panasonic PT-52DL10 52" Rear Projection...
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Samsung HCL473W 47" Rear Projection Television Logo
80 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
