Question about Kitchen Ranges
Belling cooker hood chim101 BL - light/ lamp
How do i change the light in the cooker hood. The light comes as a complete unit and apart from pulling the wires out of the back of the lights, i can't see how to change the lights any other way. I've contacted belling for the part number (082611610) but when i do a search on the net, the images show some kind of motor unit rather than a light, please help, many thanks
  • colin 2008 Nov 11, 2008
    light bulb went in cooker hood [prima] bulb smashed in light unit broke unit but cant seem to get one
I just had this very same problem and believe I have solved it!
You can remove the entire light unit from the hood. On first inspection it appears to be a sealed unit that does not allow you to remove either the wires or what looks to be a regular halogen bulb. If you turn the unit so the bulb is facing you, you can gently prise the glass from it's housing leaving the naked halogen bulb exposed beneath it. You can gently pull this from the housing and buy a new one to replace it. I would advise that when installing the new one you make sure it is completely free from any contaminant as any grease etc can greatly reduce the life of the bulb. Hope this helps!
Posted on Jan 07, 2009
Mrsomuch is almost right, its the steel cage which surrounds the glass that you have to gently prize out.
Graham
Posted on Aug 12, 2009
We have just moved house and have been left a Belling Platinum Dual Fuel db2 Cooker and cant get the ignition to work. Can anyone suggest what we should do?
by cooker,do you mean a stove? is it gas?is the gas knob in the "on" position?is the stove plugged in?
i clean out apartments to get them ready for new tenants. if the ignition clicks on,but the burner isn't lighting,it might be dirty. i soak the burners in hot water overnight. scrub with a wirebrush.poke a needle in all the openings & on the ones in the stove. dry thoroughly & see if it works.
if the ignition isn't clicking at all,one of the components in the electrical box might be broken.i wouldn't mess with gas or electric.call your gas & electric supplier or a repairman to find out what's wrong & see if it's worth fixing or not.
Mar 30, 2015 | Belling Kitchen Ranges
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
Old belling classic cooker,oven door catch has
my oven done the same so i bought some strong magnets and put one in each corner.
its fine now.
Sep 03, 2009 | Belling 644 Electric Kitchen Range
User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
Aug 21, 2008 | Kitchen Ranges
Belling DB3 Control Panel
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling db3 duel fuel cooker
they just pull out but need a fair bit of force
Apr 24, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
1,639 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
