Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Black bars across top and bottom of screen on HD programs
This happened suddenly a couple days ago and I can't figure out why. I first tried to adjust the aspect from the remote and nothing happened (it's as if the aspect button is no longer working). Then I tried to adjust the zoom settings though the menu > video and that bar is not active (it's gray and I can do anything with it). I'm stuck. Does anyone have any thoughts on how to fix this?
  • 1 more comment
  • daveje Nov 04, 2008
    The picture is fine if I play a DVD or if I turn on a non-HD channel. It's only on HD stuff that I have the problem.
    Jamie,
    The HD source is my comcast cable box. I didn't touch the settings (nor would I even know how to) before this problem started. Do you have any suggestions about where I can look to check the settings and, if there is a prolbem, how to fix them?
    Why is it that I can't see all the solutions/suggestions that have been offered (only teh most recent)? I'd like to have more than one to try if possible. Thanks
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
check the cable or replaced it!!!!
Posted on Nov 04, 2008
    Genius:
  • 1,913 Answers
Reset it press power button for 10 seconds then try.
also change resolution if porblem occurs.
    Scholar:
  • 155 Answers
Its all about the ratio of your tv to be adjusted
for the procedure check out this links.
    Master:
  • 505 Answers
In your case the aspect ratio of the picture has changed from 16:9 to 4:3 and that is why you are getting the black bars. Since you said that the remote is not working you will find buttons in the TV itself to access the menu and change the setting.
Thanks
  • 2,336 Answers
There is nothing wrong with your Plasma. Check the HD video source settings.
From where are you getting the HD video?
  • Jaime Hernandez Nov 04, 2008
    Could you please provide the comcast cable box model number?
    Please describe how is connected from the cable box to the plasma.
    Genius:
  • 2,035 Answers
Try to play DVD in the tv and check if the black bars ,if it does then this could the problem with input signal . If a menu item is greyed out there are a variety of reasons why it could be. The reasons include: the current input, the incoming resolution, and other menu items being enabled or disabled prevents the item from being selectable....
Good luck....
  • Anand Kumar
    Anand Kumar Nov 04, 2008
    Try this :
    To remove the black bars from the top and bottom press the FORMAT
    button on the remote. The option available to remove the horizontal
    bars is Zoom.
  • 728 Answers
Part of your color tube and the circuit board that controls the menu may be messed up from an electrical short. You will need a professional to check it out and to see if it can get repaired. The parts where the lines are may have been burned out and you may need a new color tube.
  • Jazz Boyce
    Jazz Boyce Nov 04, 2008
    Try doing a full tv reset by leaving it unplugged overnight and plugging it back up and see if the lines go away. If they do not, you will need to get a professional to check it for you.
  • Jazz Boyce
    Here's what you do: try unplugging the cable box from its power socket and unplug it from the back of your tv. Let it sit for about ten minutes and plug it back up and see if it works then. If it does not, you can do one of two things: you can call comcast and ask them to send you a different and stronger signal, or you can call them and ask for a different cable cord because yours may have a short.
    Brigadier General:
  • 3,614 Answers
Is this horizontal bars was only on the same spot when you turn on the tv..?
first try to adjust again the menu or try to reset the setting as well.
  • micromaster
    micromaster Nov 04, 2008
    Try plugging the power cord into a different electrical outlet and/or surge protector.
    NOTE: These
    symptoms can occur if the wall outlet is improperly wired or not
    producing the proper voltage. If using a surge protector or extension
    cord, it also could be faulty.
  • micromaster
    micromaster Nov 05, 2008
    check all the connections. its better to remove for a while the connection and put it back again. will see what happen. sometimes this problem are only with the wire connection.
I cant open pictures on my laptop
Try going into the programs menu , locate the pictures program and right click and click Run as Administrator. Good Luck
Sep 02, 2014 | Acer ASPIRE 5250-0810 Laptop Screen 15.6...
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Hi my name is Maribel
It's possible that the screen itself went defective or the controller board for the screen. It's best to use the warranty at this point because the replacement board or screen panel maybe somewhat expensive. Being that it's only 8 month old, manufacture warranty shouldn't be an issue.
Aug 18, 2009 | Sony Televison & Video
Screen shows black at top and bottom from flip video hd
I think you can use doremisoft flip converter that can crop your black bars and other addition editing functions, such as cut clips, join videos, add special effect and so on.
YOU can free download at:
http://www.flip-converter.com/article-flip-mac/flip-video-to-avi-converter-mac/
have a try.
May 25, 2009 | Pure Digital Flip Video Ultra Camcorder
Prints two bars across top only
uninstall the memory and try again
Jan 01, 2008 | HP DeskJet 5550 InkJet Printer
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Only 3/4 of the screen is being shown...
Ok so I have actually had this happen to me before. My best guess would be that it is a problem with the video card. There may be some video drivers that you need to download. The other explenation might be that the video card over heated.
When it happened to me the whole screen went blank all together after the login screen so at that point it wouldn't load Windows. If you're still covered under the warranty then you're good and set and you could get it within a couple of weeks if you send it to a tech service (preferably the company that built it)
Hope this helped
Nov 18, 2006 | Mag Innovision LT776s 17" LCD Monitor
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
