Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Moldy smell to air
We have had our units about a year .. the last three months the air smells moldy.. can you help
I have a maytag ac unit that kept smelling moldy. We tried spraying with antifungal, only helped for a short time. I took the unit (ac unit slides out of window case) outside and carefully removed screws only to discover the fan was covered in mold!!!! Oh my what a horrible discovery! I washed the fan blades with bleach and water mix. I completely and carefully washed and wiped down the air conditioner careful around the control box. Then I let the unit sit outside in the sun untill completel dry. Good bye mold and fresh clean cool ac!! I will do this each year now that I saw that ugly mold!! That is definetly a health hazard! I would reccommend you either thouroughly clean your unit or pay someone to do it or get a new unit right away!! Don't use that moldy unit another day!! Good Luck!
Posted on Aug 24, 2008
  • 80 Answers
YOU NEED TO CHECK AND SEE THAT THE UNIT THAT WAS INSTALLED IN YOUR HOUSE IS NOT OVERSIZED FOR YOUR HOUSE THIS CAN CAUSE IT TO CYCLE OFF TO FAST AND NOT REMOVE THE HUMIDITY AND CAN BE THE CAUSE OF YOUR MOLD.IF YOU SEND ME THE MODEL NUMBER I CAN TELL YOU WHAT SIZE IT IS THEY ARE RATED IN BTU'S AND HIIDDEN WITHIN THE MODEL NUMBER EVERY 12,000 BTU'S IS 1 TON SO AN RAK04259 THE IMPORTANT NUMBER 1S THE 42 IT MEANS 42,000 BTU'S AND THAT IS A THREE AND A HALF TON
Posted on Nov 29, 2007
    Novelist:
  • 75 Answers
Hi, Try spraying a small amount of an anti fugal or anti mildew air freshener onto the evap coil while it is wet. A small amount of bleach (1 tsp to 1 qt of water) mixed in water sprayed on it will also help. There is actually mold or mildew growing on the coil and in the drain pan. Do not use much because these chemicals could be corrosive to the aluminum evap coil. Let me know if this helps. kstfas
Posted on Oct 25, 2006
Try calling an air duct cleaning company
Posted on Apr 28, 2007
Does air cnditioner give any foul smell when running
Hello typically a air conditioner does not give off a foul smell, sometimes the condensate that drains out can have a moldy kind of smell or if mold is growing inside the unit it can give off a foul smell called " dirty sock syndrome". The last possibilty is that if the condensate line is drained to a floor drain and on the negative pressure side of the evaporator coil it could be pulling the sewer gas up thru the line, in this case the condensate line must be trapped to prevent this. Also, I would recommend pouring some bleach into the condensate line every few monthes.
Jul 16, 2012 | Amana Heating & Cooling
Musty smell from A/C in 2001 Pontiac Grand Prix GT SE
Most common cause is water sitting in the bottom of the a/c heater box. Make sure the outside drain is open. There are spray products for using on the vents.
Jun 25, 2012 | Pontiac Grand Prix Cars & Trucks
Moldy smell
That moldy smell that you get is from all the condensation water sitting in the condensation pan between seasons, if the unit is accessible, you could clean the algae from the pan, also, if the unit is located in a external are, it doesn't hurt to wash the coils with a coil cleaner and water.
Jun 22, 2012 | Dometic Rooftop RV Air Conditioner
The clothes smell moldy after washed in our Samsung frontloader. How can I get that moldy smell out?
1/4 cup powdered DISHWASHING soap and 1 cup bleach straight into the wash tub with a squeeze of lemon on a dirty rag HOT water wash. You may have to do this 2 to three times the first time.
Make sure your using HE laundry soaps.
There are at least 2 products out there for HE washer cleaning cycles. Tide and Affresh. It is in the laundry soap section of most supermarkets. You should use one of these type products at least one a month.
Thanks for choosing FixYa.
Kelly
Aug 16, 2010 | Samsung WF337AA Front Load Washer
LEQ1442ES--Nasty Smelling Clothes--Major lint inside
They make a 'air vent' lint cleaner and there is a handy brush made for cleaning your fridge coils that would work great. After you clean it, toss a 'Bounce' dryer sheet in to freshen it up!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 08, 2009 | Frigidaire FEQ1442ES Electric Dryer
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Thanks for your suggestion about looking in the lip of the seal. I found one of my three year old granddaughters socks. Also, the seal for very dirty so I mixed a 50% solution and 50% solution of chlorox and used an old towel rag to wipe and wash throughly around the lip seal.
I noted that the aluminum ring inside the washer had also accumulated a lot of dirt. With one hand and fingers I held the wet cholorx towel inside the ring and with the other hand spun the tub around several turns until I had removed all the dirt and grime.
It did have a moldy smell. I'll let you know if this fixed the problem.
dundat45
Jul 19, 2008 | Whirlpool GHW9100L Front Load Washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
1,793 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
