Question about Water Heaters
Vokera Linea 28 combi boiler
When the boiler pump and burner start up, it trips the electric and won't work. What's wrong?
  • 1 more comment
  • Anonymous Apr 24, 2009
    I have a Bosch PowerStar waterless hot water tank. Model AE-125. Everytime we turn on the hot water it trips the left cylinder and will not work. What could be wrong?
  • Anonymous Mar 27, 2014
    My pressure has gone down to zero and error 04, but I also can't get it to ignite? So can't up the pressure as no ignition light
  • Anonymous Mar 28, 2014
    the red light is flashing and have error code 04
    Problem Solver:
  • 17 Answers
Sounds like you have an earth leak or defective pump winding
Posted on Nov 27, 2008
Vokera mynute 28 se, plumber has replaced fan and swithch as the burner would not cut in, was beeter for a year or so, in trying to find the problem again, he has discovered that if the front plate closing...
It sounds to me like the outside air intake (your boiler requires outside air for combustion) is plugged. Bird's nest, maybe? Leaves? Spider webs? Have the plumber check outside AND where the intake air connects to the boiler.
Nov 05, 2013 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
I have a VOKERA 24 boiler the Linea range which was working fine until i notes the pressure was a little under 1.5 Barr. I topped it up the pressure with the filling loop every thing was fine. The next day...
Water logged expansion tank ( ruptured diaphram in tank) or wrong size tank. This caused the excessive pressure in the system causing the relief valve to open. Also, air in the system causing flow to stop, Both conditions will cause boiler go out on safety.
Sep 13, 2009 | Water Heaters
Vokera linea 28 boiler. I am continuously having to re-pressurise the loop (about twice weekly) also i keep getting a code 3 error appear which i know is a fan flue problem i have reset the boiler. The...
I have a similar problem with this boiler. When CH on, boiler overpressurises, (check relief valve outlet) You will then lose water from the CH loop and will have to repressurise when the CH loop cools. The problem is most likely caused by a loss of air from the expansion tank, which will need re-charged. This is not a big job as it has a standard tyre type valve connection but needs an accurate pressure gauge. Probably best left for plumber.
Mar 12, 2009 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
Fan runs continuously
the air pressure which does not controll the fan it is a safe guard for the gas/oil burner to ignite nowing that the fan is running ( air switch normaly negative /positive prssure n/o,n/c circuits. it could be that your boiler is designed for a cant think of techinacal name but when in centre of house/factory and has 1 or more boilers connected to flue etc the fans run when only power to boiler is on , non vented system ? it could be a simple link to remove in controll panel i would phone technical help for manufacture ?
Jan 31, 2009 | Water Heaters
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
Water Heaters Logo
879 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
