Question about Brother FAX-575 Plain Paper Thermal
Phone line ports
Hello,I have a probelm with my BROTHER fax-575.The external phone line works,the handset also works,The handset line does not work,I can see on the LCD that the receiver button works,but I do not get any dial-tone.Please help .
  • Anonymous Mar 29, 2014
    I checked the power, good. I checked the fuse, it looks good. I put it back in, no change. The LCD was slowly going dim and now is out. I put a phone on the line and get a dial tone.
HELLO, THANKS FOR YOUR REPLAY TO MY BROTHER FAX -575 , WILL BUY NEW ONE.THIS ONE IS OUT OF WARRANTY.COST MORE TO FIX THAN TO BUY.....
Posted on Nov 05, 2008
How do I get my fax machine to receive faxes. my manual is not clear.
First, plug a phone line to the 'Tel' port on the left side. Manual receive fax, pick up handset when fax is ringing and press 'Start' when you hear fax tone.
Auto receive - set the receive mode to 'Fax Only'
Aug 26, 2014 | Brother FAX-575 Plain Paper Thermal
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Using on voip
If your VOIP adapter has only one service line (VOIP PIN configured) then you have to remove the phone line and connect the FAX line. Now if you have the two service lines (in the both port separate VOIP PIN should be configured) - then you may connect this FAX to the other port. Both (Phone as well ad FAX) will work simultaneously. (Remember - two seperate PINS are required if you attach phone as well as FAX line in same adapter). After attaching the FAX - every think is normal like normal FAX line. Generally you don't have to dial pre country code like 011 or 00 or +, just dial the number starting from Country code.
Jun 06, 2010 | Brother FAX-575 Plain Paper Thermal
Brother 575 phone does not work?
If you can send fax out, your handset should have dial tone. If there is no dial tone, try to replace the handset cord.
Sep 17, 2009 | Brother FAX-575 Plain Paper Thermal
How do I lower the baud rate on a brothers fax 575? I want to use it with my VoIP satellite system. Thanks!
That won't work.
ALL fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
There is no work-around.
Aug 05, 2009 | Brother FAX-575 Plain Paper Thermal
Faxing on pulse line Brother Fax-575
HELLO! YOU WILL NEED TO GO INTO THE SET OF THE MACHINE, THERE IS SECTION THAT WILL ASK YOU PULSE OR TONE PUSH TONE THEN THE SET BUTTON GOOD LUCK
Feb 01, 2009 | Brother FAX-575 Plain Paper Thermal
Fax 575
The black curly cord goes from the phone receiver (handset) to the first jack on the left side of the fax (the one closest to the handset that's marked with a phone symbol). The flat grey cord is the phone cord. It connects the wall jack to the fax machine's third jack (the one closest to the back of the machine that's marked with the word "LINE").
Sep 12, 2008 | Brother FAX-575 Plain Paper Thermal
External TAD
You ought to be able to set the receive mode to tad or something like that. that way you can receive faxes without being there. Lawrence
Oct 10, 2007 | Brother FAX-575 Plain Paper Thermal
Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Jun 14, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother FAX-575 Plain Paper Thermal Logo
112 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
