Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco Vienna grinding issue
The machine grinds for a while and the bean light comes on. I have gone through this before with oily beans and I have cleaned out the grinding bin and the chute. When cleaning the chute, I could feel a small metal lever that goes up and down. Could that be part of the problem? Also, I read one fix that stated "inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that". Is that the metal piece that I am feeling?
Thanks,
  • bracheallen Dec 18, 2008
    I have the same problem. I thought that the coffee was getting stuck in the shoot and the door was not opening to allow the coffee to drop down to the filter press mechanism. In the past, cleaning the coffee out of the grind area seemed to cure the problem but it has not worked this time.
    if it is the micro switch I have three questions, what does the micro switch do, is it hard to replace and where do you buy one?
    Thanks.
    Jamie B.
I changed the micro switch, and that did the trick. Thanks
Posted on Dec 02, 2008
  • 515 Answers
I think so, most problem with that the grinder grind to the lamp light up is damp in the grinder or oily beans.
if you have two adjustment knob in the bean hopper then the second problems can be the micro switch in the machine that have to be replaced.
Best regards
/Mirran
Posted on Nov 08, 2008
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
The grinder spins but no beans get grided. sometimes if i push them down it will work for a while.
Remove all beans from grinder and with the remain beans adjust the grinder to more gross grinding and the make 3 to 4 coffees.
Then Use a vacum cleaner and absorve as much from the grinder. Wash also the Beans hopper with soap and hot water so all oil remianing go away. Dry it very well and put back in place.
Now add new add some new beans and try to make an espresso and when the grinder spins then rotate back to the original grinding position. Remeber that you must go back to fine one step at a time not at once since this will blocked the grinder blades with grounded coffe and grinder will not rotate.
You should to this often is you use oily dark roated beans beans. I sugest to find also a better quality beans which are more light color thus less oily.
Aug 25, 2010 | Saeco Vienna Espresso Machine
Red warning light comes on in my saeco vienna deluxe I just aquired this unit and to date have not been able to make a cup of coffee. All the green lights light up and coffee starts grinding but after that...
Hi
More than likely your grind is to fine and you are using oily beans (shiney). There is a small knob in the bean hopper. turn it down to the minus side. Turn the big knob to the # 18. If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
After grinding no coffeee comes out
If you open the steam knob and make a cup of water (the), can you get any water comes that way?
If not then i think you have calcium in the system.
If the grinder goes for long time it can be oily beans or if you get damp into the grinder.
Let me know if you need more help.
Best regards
/Mirran
Jan 17, 2009 | Coffee Makers & Espresso Machines
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
260 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
