Question about Frigidaire 25 in. FDP750RC Free-standing Dishwasher
Frigidare Dishwasher/rolls around
The water normally 2 fans that spin around to spray the water. Yet they no longer spray. The 2 just sit in one position now so the dishes all are not clean.... Please advise. Thanks Nick Douglas
    President:
  • 878 Answers
Nick, check the spray arms themselves to make sure they are not clogged, cracked or split. You have a seperate wash and drain motor on this model. It could be the filter under the lower spray arm is completely clogged with food gunk. You would have to remove the spray arm and get down to the filter. The wash motor itself has a small impeller on the end. It may be broken or the motor itself is bad. You would have to pull the dishwasher, the wash motor comes off very easily with just a couple of screws and you can examine the impeller. Catriver...post back
Posted on Oct 04, 2006
Loud Noise from Maytag JetClean Dishwasher
Here is the parts diagram for your model:
DWU8260ABX (http://click.linksynergy.com/fs-bin/click?id=YO6223WzStY&offerid=122738.560449854&type=10&subid=)
Look at diagram #7 the upper spray arm should just unsnap.
The grinding, clicking sound would be your blower motor in diagram #1.
Jul 01, 2008 | Dishwashers
Dishwasher does not spray water just trickles out.
Ok this normally happens when there is a leak in the base
pull it out and remove both side panels
Do you see any water in the base
look on the left side there is a red bar which goes down to the botton lift this up and down you should hear the swich clicking make sure the rod is down then retry it
The micro screen maybe clogged but the main culprit may be the larger filter found inside the unit upon which the spray arm sits. It has sometimes significant calcium type deposits that I nearly completely cut off the water flow.
http://www.acmehowto.com/howto/appliance/dishwasher/check/sprayarm.php
Link above is how to check, your spray arms, to test.
Water comes into the dishwasher not through the spray arm.
It comes through the water inlet valve out of the hole on the left side of the tub.
The lack of the pressure could be if it is not enough water came into the dishwasher during the fill up time.
Add a 1/2 of gallon of water manually and see how the spray arm spins. If it spins better then the next step is to check the water shut off valve under the sink. Is it open all the way or not?
If it's fine then the problem is the water inlet valve. It could be blocked with hard water deposits or it's not opening all the way. In both cases it has to be replaced.
Apr 08, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
The dishwasher makes a horribly loud sound when running. I think it has to do with the lower "spinner arm". When I push it manually, it wobbles and makes noise. So I am guessing that spinning at higher...
It's noisy If your dishwasher seems noisy, check these: Water-inlet valve Motor Heater fan Pump Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve. Motor If it's the motor that's noisy, either of these may be the "culprit:" As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later). If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor. Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it. Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Nov 19, 2009 | Whirlpool Dishwashers
Motor will run but no water comes into dishwasher
Water-inlet valve
Motor
Heater fan
Pump
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Jul 24, 2009 | Dishwashers
NOISY DISHWASHER WHIRLPOOL GU3600
Water-inlet valve
Motor
Heater fan
Pump
Jul 24, 2009 | Whirlpool GU3600XTS Dishwasher
Kenmore model 665
You need to check the arm's holes for clogs. If the water is filling and draining well, the only water that circulates is being pushed up through the center hole or tower.
The angles of the holes cause them to be little jets when the water rushes out. No water getting through = no jet = no spin.
Jun 30, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Loud noise at end of Draining
1. Water-inlet valve
2. Motor
3 Heater fan
4. Pump
Water-inlet valve
Motor
Heater fan
Pump
good luck
thanks for using FixYa
Jan 28, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Dishwasher Repair
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 10, 2007 | Dishwashers
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire 25 in. FDP750RC Free-standing Dishwasher Logo
161 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
