Question about JBL GTO 301.1 Car Audio Amplifier
Keeps swirching to protect mode
My amp keeps switching on and off from power to protect no matter if the car is switched on or off and even if the music is loud or quite. what can i do to get it working properly?
    President:
  • 3,130 Answers
First thing to do is disconnect all of the speaker wires on the amp. Turn on the amp, if it is still turning on and off then there is a definant problem in the amp circuitry. If you have no solid state service skills, I highly advise you to take the amp into a repair shop. If it stops turning on and off turn off the amp and try and connect up one speaker at a time untill the amp starts to mess up. you then take that speaker and have it checked out and inspect the wireing for pinchs or shorts.
Posted on Oct 03, 2006
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
How intelligent is Pioneer's vsx amp/rec "power off" protecting mode? Hi, I would like to have an answer to the foregoing title in order to find out if it's worth repairing my Pioneer...
When you remove boards, you may be breaking a circuit somewhere that is causing the shutdown. Pioneer uses rear panel jacks for ground points a lot, and if even one of these screws is out it can cause it to shut down.
Sep 26, 2013 | Audio Players & Recorders
I have a JBL GTO 7001, it switches in an out of protection mode. i pulled out the amp, an noticed that the positive wire from the speaker was pulled out. so i disconnected the power scorce an reconnected...
Make sure that your positives and negatives are lined up correctly. This happened to me during my latest install and the problem was I had one positive speaker wire plugged into a negative speaker terminal. This switches the amp on after a few seconds and then back to protect mode once it detects a faulty speaker wire. Hope this helps!
Oct 07, 2010 | JBL GTO7001 Car Amp
My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
Poly Switch
All full-range loudspeakers are fitted with a self-resetting
poly switch that protects the high-frequency driver from
damage caused by excessive power.
If a loudspeaker cabinet loses high-frequency output, immediately
remove power from the unit and wait for two to three
minutes. They should allow the poly switch to reset. Reapply
power and check the performance of the high-frequency
driver before continuing with the power reduced to a
level that does not cause the poly switch to interrupt the signal.
On the SW115V/SW118V/SW218V sub woofer, the Poly
Switch protects the woofer and a similar routine should be
followed if its output is lost.
Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
Amp won't come out of safety protection mode. have soldered many suspected dry joints and checked voltages on IC502 (Power Amp IC) PLEASE help!!!
The protection mode is often switched on when an overload has/is happened/happening. This is caused more often than not by faulty speaker wiring or problems. It sounds to me like IC502 might well be the cause, or perhaps a faulty relay if it uses one. But IC's are often to blame, this one might even control the protect mode!
Jun 04, 2010 | Audio Players & Recorders
Amp pulses from power to protect
check it without the speakers if they go to protection,and if not check the speakers
May 27, 2010 | Power Acoustik PS4-800 Car Audio Amplifier
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Denon AVC-A1SE in protection mode
The numbers of the transistors thay you need to replaced are on the transistor themselfs. Just take out the bad transistors and get the numbers that you need. I ALWAYS replace the output, driver and bias control transistor myself. One thing to keep in mind, if the number on the transistor starts with "A or B or C or D or K" you need to add "2S" in front of that number when you order it. Now that this problem has repeated itself, double check your wire and speaker. They can cause this problem.
Nov 09, 2008 | Audio Players & Recorders
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
JBL GTO 301.1 Car Audio Amplifier Logo
267 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Morne Olivier
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
