Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
There are no low speeds. Runs medium on "stir" setting.
Old K5SS solid state
  • msetley2 Nov 30, 2008
    No 'stir' or low speeds--runs on high speed only.
See the solution at http://www.fixya.com/support/t501377-speed_switch_gone_beserk
Posted on Dec 27, 2008
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Model K5SS -- The speed control lever will not stay in the slowest position - STIR - but will pop over to the next position - 2. Can I adjust anything to fix this problem?
Open up the Motor Housing and inspect the Switch Lever with Stud.
The Lower Gearcase has many depressions which allow the stud to
snap into it when the Speed Selection lever is moved. If the Stud
is worn out then there isn't much you can do but replacing it.
3184193 is the Switch Lever And Stud part number for your model.
Jul 03, 2011 | KitchenAid K5SS Heavy Duty Commercial...
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 28, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Motor does not start until switch is in 4-5 position, also the arm does not turn.
It looks like you may have two different problems. First, you must adjust the mixer speeds.
Second, if the motor runs at different speeds but the Planetary Assembly does not rotate, then
you may have a stripped Worm Gear Follower.
The K5SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 23, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Our K5SS 300 watt mixer (30-40 years old) does not have a really slow speed anymore. We used it with the vegetable grinder accessory and when we were done it would not go slow on the slow speed. It went as...
the speed setting is in the speed control unit which by your statement is now broken
no parts around for the lovely old reliable machine which is now close to junk
take it to an appliance repair shop as they may have spare from another machine or can repair the fault
Nov 15, 2017 | KitchenAid K5SS Heavy Duty Commercial...
The kitchenaid k5ss runs at high speed at every setting of the speed control. How is this adjusted?
This is a bad rheostat switch. You will need to visit a repair center to have this fixed or get the part you need.
Mar 06, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Jan 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Nov 14, 2008 | Hobart HL600 Legacy Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
200 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
