Question about Onkyo TX-SR875 Receiver
Onkyo amp keeps turning off - Onkyo TX-SR875 Receiver
  • B00718 Nov 07, 2008
    Speaker wires were reversed on front speaker thanks to the cleaning lady accidently pulling the speaker wire out.  A better first attempt than fuses.
I had this problem happen to me a couple times until i noticed that the first fuse near the power cord kept blowing. either change it or get surge protection cicuitry
Posted on May 29, 2009
  • 86 Answers
Check your fuses sounds like one may of blownout
Posted on Nov 04, 2008
How do I fix my receiver if it is shorting out
units going into protect due to fault - try turning unit on without speakers if unit is ok check speakers
Nov 30, 2014 | Onkyo TX-SR506 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
I have an Onkyo TX-DS747 & everytime I turn the receiver on the speaker outputs a switch keeps turning on & off for about an hr before it rectify it's self. Is there a way to correct this issue??...
What it sounds like you are describing is the protection relay turning on then imediately turning off for the time period mentioned. That would indicate a possible short in the circuitry. Probably a capacitor that is intermittant or even a transistor about ready to fail. This is probably not something you can look for if you are not an electronic tech. Find a reputable shop and get it fixed before it quits and does more damage. Let me know how you make out.
hardrocko
Feb 03, 2010 | Onkyo TX-DS787 Receiver
Onkyo tx 906 amp
1) I bought the same Onkyo model from goodwill a couple years ago and it had the same problem. The solution is simple: Get yourself some Deoxit D5. This is a spray that will clean out all the oxidation in the volume pot. To do this you'll need to remove the cover of the receiver. Deoxit can be bought at guitar shops, or if you know a musician they might be willing to do it for you.
2) User manual is available for download, for free. Google "Onkyo tx-906 receiver manual".
Mar 17, 2009 | Onkyo TX-DS575 Receiver
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
Amp turns off after about 20 mins of bluray playback
Your amp is overheating. Provide better ventilation or rig up some fans. Onkyo amplifiers are known for getting hot.
Peace.
Marco
Feb 05, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Nov 09, 2008 | Onkyo TX-SR605 Receiver
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
Amp keeps switching off
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the shop to be diagnoised. Good Luck
Apr 29, 2007 | Onkyo TX-SV373 Receiver
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
591 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
