Question about LG W1934S-BN 19" Monitor
Lg flatron w1934s blank white screen no menu - LG W1934S-BN 19" Monitor
sys_admin
  • 829 Answers
SOURCE: lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
Posted on May 10, 2009
angelo23
  • 53 Answers
SOURCE: Flatron W1934S screen has suddenly started to go bright pink
clean the graphics card first
Posted on Sep 06, 2009
Geekman
  • 32281 Answers
SOURCE: Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Oct 02, 2009
  • 37 Answers
SOURCE: my lg flatron model w1934s was working fine but
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
Posted on Oct 10, 2009
neutronrace
  • 66 Answers
SOURCE: LG FLATRON W1934S
hi,
check first if the connector has no connector pins wha are broken or shifted. if not chack cable for hard nobs or turns maybe cable is interrupted.
take other schreen to check VGA output of PC.
if all this not helps mail me back
greetings cis
Posted on Feb 16, 2010
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
My LG Flatron W1934S screen is now blank - the power light is blinking on and off, but no picture.
There is no problem with monitor, there is no signal from your VGA card, looking for a problem in your case.
Apr 29, 2012 | Computers & Internet
Hi my LG w1934s LCD monitor suddenly not working it screen is full with color lines even I disconnect the VGA cable from the system unit the screen is not change the color lines are as it is what can I do...
That have not simple solution better take it to a tv repair shop, you already disconnect the data cable and discard the possibility of computer problem.
The Monitor must have in the menu a reset configuration option but I doubt it will help, its time to get it to a repair shop.
Mar 17, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
I want lg flatron w1934s drivers.please tell me how can i search them.
Hi, i would search on DriverGuide.com.... its the safest place. Most other driver download
sites are infested with pests that can bug you to no end.
Jan 23, 2011 | LG W1934S-BN 19" Monitor
www.lcdparts.net
Oct 02, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
What is the best method for cleanig a flatron
Take a clean cloth and spray some windex on the cloth and then wipe down the screen and it should come nice and clean. Never spray it directly on the screen cause if the liquid goes down inside of the screen then it could damage it.
Mar 01, 2009 | LG 22" FLATRON LCD Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
LG W1934S-BN 19" Monitor Logo
1,079 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
