Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Frig and Freezer not cooling, no fan, but interior lights work. Temp display not working
I have a GE Profile side-by-side fridge, model # PSS26SGRCSS. The unit is no longer cooling and the fan no longer operates. The interior lights do work, however. The control panel display inside the fridge no longer displays the temperature setpoint for either the fridge or freezer. The only light on the panel that works is the "hrs" display on the custom cool section. This part of the display blinks every 2 seconds or so. A close inspection of the unit also reveals a fairly quiet, cycling noise that lasts about 2 seconds and continues to repeat. It almost sounds like the compressor is trying to start up. When I open the refrigerator or freezer doors, the noise continues but it isn't as loud (almost as if one of the components no longer tries to start when the door is open.) The noise(s) originates from the back of the fridge, near the bottom. The fridge also had a clicking noise that originated from the back control panel, but that noise stopped after I removed the panel and re-secured the ground wires. Any ideas? Thanks!
  • k_trick Nov 04, 2008
    OK, I 've now tried unplugging the unit. Unfortunately, it still is behaving the same way. Now by holding in the light switch, I get the same cycling noise that repeats every 2 second or so (regardless of whether the door is open or not.) It is a very quieting whirring noise that starts only slightly and then stops (and then repeats.)
  • butch welch May 11, 2010
    Lets start by holding your light switch in and turning your light out. Some fans wont run with the door open. No, lets start by unplugging the fridge for 5 minutes to see if thing default to factory settings, then we will try the light switch. Hold switch in for at least 15 seconds.
aasc
  • 1606 Answers
SOURCE: GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Posted on Jul 23, 2009
  • 74 Answers
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Posted on Aug 28, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
aasc
  • 1606 Answers
SOURCE: I have a GE profile side by side model
Yes , the main control board is the problem . Also , make sure the coil roll behind the refrig , is clean . Sounds like the compressor relay on the board itself , is doing the clicking , trying to start a hot compressor , either caused by a compressor cooling fan not working , or the board . If the compressor cooling fan is not working , the board is still probably the problem . I have found , the board clicking , trying to start the fan . Replaced board , and no more problem .
Posted on Sep 25, 2009
Testimonial: "Thank you so much. "
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Frig side does not cool. freezer side cools
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
FRIG DOEN'T GET COLDER THAN 49, WHAT COULD BE THE PROBLEM,FREEZER WORKS GREAT (GE PROFILE) ABOUT 2 YEARS OLD-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge Profile Freezer not working
Main pcb failure but just check the wireing at the bottom of the freezer door as it can affect the control system
Feb 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi Guys, I have a GE Profile Frig: PSF26NGTDBB Serial # SL416129 This AM the softdrinks seemed a little warmer than usual. We checked the digital temperature inside the frig compartment and the freezer...
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Oct 09, 2008 | GE Refrigerators
Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Feb 02, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
220 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
