Question about Hoover Floormax F4300 Upright Wet/Dry Vacuum
One brush stopped turning
One of the bruhes stopped turning everything eles seems to work. I took it apart and cleaned it and looked for broken or loose fittings, all looked fine
4 Suggested Answers
SOURCE: hoover steamvac brushes don't spin
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Posted on Feb 20, 2009
  • 97 Answers
SOURCE: i have a hoover steam vac f5899-100
if after you cleaned the brushes and still doesn't work. it will have to be the turbine assembly that the brushes fit into.
Posted on Jul 20, 2009
  • 400 Answers
SOURCE: BRUHES WON'T ROTATE
The bearings in the turbine that turns the brushes are very cheap. They rust and seize. Sometimes they can be greased and reused. If the corrosion is too bad the turbine has to be replaced.
Posted on May 01, 2010
Eureka TRUE HEPA Whirlwind Bagless same problem seems...roller just stopped...took everything apart and turned it on just in time to see belt melt...I was able to get the end caps off both sides at first...
If you are able to remove one end cap, the brush roller shaft can be removed and the other bearing is exposed for examination and removal of the hair that probably is clogging it. After cleaning and reassembly the brush roller should rotate freely. Clean any burned belt residue from the motor shaft and install a new Eureka belt.
Aug 02, 2013 | Eureka 2961AVZ Bagless Upright Vacuum
My Dyson DC14 Animal brush stopped spinning after I cleaned out the hair on the brush. I took everything apart thinking something got stuck, and nothing was found. I took off the grey floor attachment and...
I'm sorry to hear you're having difficulties with your DC14. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue you're experiencing, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 04, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Brush is not engaging when vacuuming. If lifted
therre are usually aprings that hold the brush in position or a spacer thaqt turns when you adjust the height. turn the vacuum over and remove the plate covering verything. make sure your unplugged first. it usually takes about 5-6 phillips head screws. look for loose ,broken or missing parts. make the the roller is taken out and is carefully cleaned of all hair etc esp that just at the edge of the roller where it meets the monting devices. the hair and debris often gets stuck there and once removed works much better. also make sure the belt is not stretched and is slipping on the brush. if it is replace it. good luck.carefully reassemle the parts you removed being very aware of what postiotn everything was in when you took it apart. make sure everything has proper clearance and then test your vacuum. if you find broken or missing parts replace them first ofcoarse.
May 14, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Brushes won't turn
Look at the ends of your brushes were the brush piece attaches to the vacuum. Sometimes they are broken or just stuck. good luck
Dec 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes stopped
Most likely the turbine is bad, it may just be clogged up, you can take it apart and clean it out real good. That may work, but it may not. Sometimes it is best to replace the turbine.
Jul 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover carpet cleaner
Take the brush block out, is the shaft that goes up into the turbine there, or is it broken off. If gone, then replace the brush block. If there, then probably the turbine isn't working, this is what drives the brushs. It may be just clogged up, you can remove the turbine, take it apart and clean it out real good and put it back together. If it works, then you are set, if not, then it will have to be replaced.
Mar 24, 2008 | Vacuums
Spin brush not working anymore.
Is the shaft still on the brush block, if it broke off, then replace the block. if it is ok, then the turbine(#13) is most likely the problem. It is what drives the brushs. You may be able to take the turbine apart and clean it, if that doesn't work the replace it.
Mar 15, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Floormax F4300 Upright Wet/Dry Vacuum Logo
37 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
