Question about Boating
Tilt and trim
I hoooked my negitive wire to a positive post and tried to start my motor. Since then my tilt and trim stopped working. I replaced the relays and I have power going to them. I'm able to use a jump wire from the hot going into the relay to a wire coming out of the relay and it will then work. I have power going and coming from the switch at the helm but not at the switch at the motor
    Problem Solver:
  • 4 Answers
Check the cable from the helm to the motor. Put a tone set or multimeter on it. If that cable is still fine then check that your new relays are functioning correctly.
Posted on Nov 05, 2008
On my 50 Yamaha two stroke I have power to the trim motor from the green and blue wire but no movement. I have a clicking sound when I move up or down is the motor bud?
Sounds like faulty trim tilt relay.Connect blue green wires direct to battery ,if motor goes up or down then trim is ok but relay is faulty
Aug 10, 2015 | Boating
Tilt and trim wont trim up taking off works fine running down the lake
Check trm/tilt release screw,does trim motor run but motor doesn't lift,if trim motor doesn't run then it's probably trim solenoid/relay
Oct 09, 2014 | Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
Aug 16, 2014 | Sierra International 18-6756 Marine Power...
Evinrude 225hp will not power tilt batteries OK manual release will turn but still not able to tilt motor?
Check trim tilt switch (if that's ok ) Try the trim / tilt relay inside the engine cover.
Could also be limit switch above the trim motor up further under the motor.
My bet is switch or relay
Good luck
Aug 14, 2010 | Clymer EvinrudeJohnson Outboard Shop...
My tilt on a yamaha ox66 200 motor quit working,what should I try first?
Step 1:
Operate Trim Switch Do You Hear Clicking Sound In Engine
Yes ,No
Step 2:
If Yes Check Wiring To Power Trim Motor are All Cables Tight
If No Then The Trim Relay And Or Trim Switch Is Probably At Fault
Step 3:
,Remove Three Large Color Wires Going To Power Trim Motor Black, Blue And GreenConnect Black Direct To Negative Battery And Blue To Positive Battery Motor Should Trim Up ,Remove Blue Then Try Green To Positive Battery, Motor Should Trim Down ,If Nothing Then Trim Motor Is At Fault If Works Then Trim Relay/s Are At Fault
Jul 03, 2010 | Boating
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
I have a 1994 150 hp Yamaha outboard motor with tilt-trim. My motor is stuck in the up tilt position and will not tilt down. It is working when I go up, but not down. I have talked to a used parts dealer...
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Jul 14, 2009 | Boating
Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
Mar 28, 2009 | Boating
Boating Logo
328 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
