MLTD3222 has sound but no picture
Hi.. This Memorex TV had a picture and now none but I can hear the sound. Please help...
  • 2 more comments
  • tmoberg Nov 14, 2008
  • Anonymous Dec 01, 2008
    I have a emerson 13" tv vcr combo. It has sound but no picture. How do I fix this.
  • soccerlover2 Jan 05, 2009
    mltd3222 has sound but no picture now
  • 32374K Jan 16, 2009
    MLTD3222 has sound but no picture problem
    Novelist:
  • 131 Answers
I have one of these in my shop with same problem. Unit has sound but no backlights due to the powersupply/inverter board ( top board in metal box. The lights come on for a second and go out. Problem was originally intermittent. You can order this board from Fox Intl Part but will take a minimum of 12 weeks. Look at the lower right corner of this board and locate the dip switch of 4 positions. the bottom one is labeled " normal & burn " Try moving it to "burn" My set is in the burn position and has been running for 2 days now OK
Posted on Jun 26, 2009
My mltd3222 quite working yesterday and after reading the post above I fixed it. All you need is a screwdriver, take out the large screw in the middle and the two small screws above the inputs then slide the center plastic piece down and off. Next remove the metal cover and look in the upper left corner for a white box with four switches on it, move the #4 switch to the right or burn as indicated by the chart. Mine works now.
Posted on Mar 30, 2010
  • paula Jul 19, 2013
    thaaaaaaaaank you !!!!! i did what you said , and it works great now :) :)
    Problem Solver:
  • 5 Answers
I tried the solution to replace the Z6 diode with no success. However, I found that, if I hold the Volume down (-) button while turning on the unit, it works! I depress the Volume (-) button and, without releasing it, I press and release the Power button. I continue holding the Volume (-) button for about 10-15 seconds before MEMOREX display appears. It does not blink off; and the TV comes on within a few seconds.
My MLTD3222 has been working for several days. Sometimes, it will start rigth up...at other times, I have to repeat the process described above. The total cost of the fix/workaround was $0!
Posted on Oct 01, 2009
I have the same problem, it happens every couple of weeks, I just unplugged everything and then plugged the power cable back in and jiggled it rather rigorously and then pressed the power button...it works now. It will probably stop working again soon but I will just repeat these steps. Hope it helps!
Posted on Dec 15, 2011
Posted on Nov 14, 2008
How to do an update on memorex lcd mlt 3222
If you mean a firmware update to the MLTD3222, there is no way for a user to update this TV with built-in DVD player. The manufacturer doesn't provide updates and has no way to access them from a DVD, USB flash drive or SD card. (The manual for the related MLTD2622 is available from Memorex support: http://support.memorex.com/app/answers/detail/a_id/939 . )
I wish that I had better news for you.
Jul 08, 2014 | Memorex MLT3221 32 in. LCD TV
Need tv codes for a memorex mltd3222 tv/dvd combo for my direct tv remote
The Dish remote like others only has about 50 possible codes in it--these combo units use odd codes so that remote may just not be able to be programmed for this unit---the remote should have a search mode that allows you to try one at a time every possible code it contains.
May 16, 2012 | Televison & Video
No picture but sound. When turning the tv on the
Power supply issues - I bet bad capacitors 'dried out' .
A good servicer should be able to fix it for you.
Nov 19, 2009 | Imation MLTD3222 32 in. LCD TV
Memorex 1080i hdtv model# mltd3222 32" LCDTV with built in dvd player I have sound but no picture. When i turn it on, the memorex symbol comes on, then black screen for duration. Any help would be...
I work for Memorex tech support. Our number is 800-919-3647.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty is one year from the date of purchase. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jun 22, 2009 | Memorex MT1701 17 in. HD-Ready LCD...
MY memorex mltd3222 sound disappeared
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Please post a comment if you need additional assistance so that I can help you further.
Jun 12, 2009 | Memorex MLT3221 32 in. LCD TV
The memorex brand icon comes on briefly when i turn on the set
Try the link.It may help.
http://www.devicemanuals.com/guide/Television/Memorex/Memorex-MT1134-13-Color-TV-with-front-A-V-jacks-T1RJMU5UTT.html
Jun 01, 2009 | Memorex Televison & Video
No picture on Memorex MLTD3222 flat panel LCD.
I recently got this tv from somone because of this exact problem. I have found a solution that works for mine. You can check to see if it works for you also. What I did was take of the back cover. 3 screws (1 big one in the center and 2 little ones below it). Next look at the power board. If plugged in and turned on the red light on the power board should be lit up. If so your power board is fine. Next find the component that has 4 switches. I manually turned these on and turned the tv on and it worked! Has been working ever since!
Jan 27, 2009 | Memorex MLT3221 32 in. LCD TV
Can not access menu or input functions
Hi rduncan27,
I will be happy to help. 88% of LCD tv problems are with the backlight, the symptoms you described indicate a probable inverter malfunction. Lets do a simple test to check the functionality.
  1. Get the tv to a point that it is producing sound.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely for a dark video image.
Let me know your findings and we can proceed from there.
Lone99star
Jan 26, 2009 | Memorex MLT3221 32 in. LCD TV
19 inch portable TV Memorex
Hi! I realize that you posed a couple years ago, but I am having the same problem with my relatively new Memorex MLT 3221 model. How did you solve it??? I have tried every 'layman' solution that I can think of! Please help!
Dec 31, 2006 | Memorex MLT2022 20 in. EDTV-Ready LCD...
Televison & Video Logo
834 people viewed this question
Top Televison & Video Experts
