Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
Wiring pool pump mdel 1081
Is there a diagram as to how you wire your pool pump. I have already hooked up the lines but not sure how to wire the motor from the timer box
  • 1 more comment
  • abd635 Jan 31, 2009
    electrical connection form the box to the motor
  • lenard c staskiews Jun 13, 2013
    what color wire goes to what terminal on the back of the moter for 120 volt
    yes the wires are red black white green i khow were the green goes.
  • 22 Answers
The motor has a label on it that will give the connections. For a 240V circuit, you should be connecting to the two screw terminals in the back of the motor and a ground to the green screw.
Posted on Dec 22, 2008
CAN I WIRE THIS PUMP TO RUN OFF 110 OR DOES IT ONLY USE 220
There should be a wiring diagram on the side of the motor. It will show wiring for 220V,or 110V, or both.
Jun 22, 2015 | Pool & Spa
My motor has black, white, and brown wires coming out of it. I had sketched the connections but left it out in the rain and now don't know how to hook it up.
Are these the wires that come from a power source to the motor?
Which are called Line wires.
if these are Not Line wires, then they are the motors internal wires, and you could be out of luck? You will need the manufacturers wiring diagram.
If they are Line wires, then simply... Get a multimeter, turn power on, and test each wire to ground. This will tell you if and which each wires is line/hot or not.
Jun 06, 2015 | AO Smith Pool Pump Motor Hayward Swimming...
Where can I find a Wiring diagram for hayward super II PUMP AND BOOSTER PUMP to new t106 intermatic and existing t104 for the booster?
Not sure if you will find such a diagram...
New installation?
Do the pumps have their own breaker?
Is your Super II pump a 2 speed?
What is the Thermostat for? Do you have a heater that you are trying to connect, so that the pump will come on when there is a demand for heat? Not really sure what the T-stat is mentioned for here?
You still only need to have 2 timers if I'm not missing something?
The T-106 will be for the Super II pump (presuming it is a 2 speed version) It will turn hi speed, on & off. or switch between them rather. I think I see why you may be inferring about a 3rd timer? You don't want to have pump running on "Low" speed continually. If so, Then you will need a 3rd timer (T-104) to provide power as Line to the T-106. The other T-104 will be for the booster pump for your cleaner.
The power for the Super II pump from the breaker will go to the 1st T-104 as "Line". Then from the Load portion of that timer, you will wire into the Line portion of the T-106. Following the instructions from the diagram at this website address for a PDF document:
http://www.intermatic.com/~/media/Intermatic/Documentation/Time%20Switches/Mechanical%20Time%20Switches/24%20Hour/T100%20Series/T106R%20Instructions.ashx
you will complete the wiring to the Super II pump via the "Load" side of the T-106
The 2nd T-104 (pool sweep pump) will be wired: from the breaker to the "Line" portion of the timer. From the Load portion of the timer, you wire to the booster pump.
Good Luck
Apr 29, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring MTD2
Here is wiring for non-motor loads up to 2000 watt 230V:
http://waterheatertimer.org/images/MTD2-timer-wiring.jpg
Here is wiring diagram for controlling motor load:
http://waterheatertimer.org/images/MTD2-timer-wiring-motor.jpg
Gene
h
Feb 08, 2014 | Hardware & Accessories
DTD 1440-1 universal timer> how do you wire up for swimming pool pump> wires at pool pump = RED, BLACK, BLUE AND BROWN
Copy following link for DTD 1400 timer wiring diagram
http://waterheatertimer.org/How-to-wire-DTD-1440-timer.html
Use a contactor for heavy-amp load like motor drawing more than 1/3 Hp
Motor wiring diagram appears on side of motor
Gene
h
Aug 11, 2013 | Hardware & Accessories
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Intermatic T103P Timer (120V) Wiring Guidance
Copy following link for T103 timer wiring options:
The clock motor is 120Volts, but clock motor can be changed from WH1570 to WG1573, and this action changes 120V T103 into 208-277V T104 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Jun 08, 2012 | Intermatic Hardware & Accessories
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
2,874 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
