Question about Apple iPod nano
CHANGE NAME ON SCREEN SCROLL
MINE IS AN 8GB CAN YOU HELP ME
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Are you wanting to change the name on your ipod?...If so:
  • connect you ipod to you computer & bring up itunes
  • when your ipod appears, click on the name,and change it
  • sync & eject, will have the name you want on it
-----John
Posted on Dec 03, 2008
How to open mms
IF you use cingular you can use these settings. However, if you use a different service provider you will need to change the server name depending on the information that your service provider gives you.
  • From the standby screen, press Menu.
  • Scroll to and select Messaging.
  • Press Menu.
  • Scroll to and select Inbox Setup.
  • Select MMS Message Setup.
  • Scroll to and select Server Info.
  • Scroll to and select Cingular MMS.
  • With "Cingular MMS" highlighted, press Menu.
  • Scroll to and select Edit.
  • Validate the following parameters:
  • May 03, 2011 | Motorola Mobility RAZR V3i Cellular Phone
    I have bought my partner a 16gb ipod touch 2nd gen in place of her 8gb which i now have how do i change the name of the ipod to mine and delete the music on it and replace it with mine?also apps and...
    connect to your system with itunes and under the summary tab you'll find restore option...just click on it and follow on screen instructions...it'll become as good as new...
    Aug 23, 2009 | Audio Players & Recorders
    HOW DO I CHANGE THE NAME(OF FAXER) ON OUTGOING FAXES?
    Try MENU,*, w9 to get into Initial Programming then scroll to the "Name "you wish to change
    OR try
    Program, I(capital letter I ), ENTER to access initial programming then again scroll to nam you wish to change.
    Mar 15, 2009 | Muratec F360 Plain Paper Laser Fax
    It froze and the reset wont work
    this is james again my email is jamesboggs18@yahoo.com mine is 8gb the name is philips it is going to a white screen it will not let me acsses the music it turns on to a white screen thanks......James Boggs
    Feb 09, 2009 | Philips GOGEAR SA6045 MP3 Player
    Fuji f700 memory card full error
    Simple fix... go into the setup mode and scroll down to Frame No. option and change from Cont. to Renew by touching the right scroll button. After that exit/save the changes and it will then work again. However, I put mine back on Cont. and all was just as it had been prior to having that problem. It may be some internal counter that simply runs out possible, thus Renew will reset/repoint the counter, and after that you can change it back and it will again name files continuously which I find most helpful.
    Hope it is helpful for you.
    Feb 08, 2009 | Fujitsu Cameras
    Ipod nano 8GB 3rd generation FROZEN!
    You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
    Aug 09, 2008 | Apple IPod nano Second Generation MP3...
    Canon LaserCLASS 710 Fax Owner's Manual
    Set Speed Dial / One-Touch Feature
    1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
    2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
    3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
    4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
    5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
    6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
    7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
    8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
    9. Press the red “Stop” key on the main control panel.
    10. The “One-Touch” feature is now set.
    Label corresponding “One-Touch” button with company name.
    Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
    Cannot send or receive pics
    Here are the MMS settings you will need to setup and/or verify:
    From the standby screen, press the Menu Key.
    Scroll to "Settings," press Select.
    Scroll to "WebAccess," press Select.
    Scroll to "Web Sessions," press Select.
    Scroll to "Cingular MMS" press Menu.
    Scroll to "Edit," press Select.
    Homepage: http://mmsc.cingular.com
    Service Type 1: HTTP
    Gateway IP: 66.209.11.32
    Port 1: 9201
    Domain 1: leave blank
    Service Type 2: WAP
    Gateway IP 2: 0.0.0.0
    Port 2: 0
    Domain 2: leave blank
    DNS 1: 0.0.0.0
    DNS 2: 0.0.0.0
    Time out: 5 minutes
    CSD no 1: leave blank
    Username: 1: leave blank
    Password 1: leave blank
    Speed (Bps) 9600
    Line Type 1: ISDN
    CSD no 2: leave blank
    User Name 2: leave blank
    Password 2 leave blank
    Speed (Bps) 2: 9600
    Line Type 2: ISDN
    GPRS APN: wap.cingular
    User Name: WAP@CINGULARGPRS.COM
    Password: CINGULAR1
    Press Done.
    Press Exit.
    Press Back
    Press Back.
    Scroll to "Messaging," press Select.
    Press the Menu key.
    Scroll to "Inbox Setup," press Select.
    Scroll to "MMS Message Setup," press Change.
    Scroll to "Server Info," press Change.
    Scroll to "MMS", press Menu key.
    Scroll to and select "Edit".
    Validate the following settings:
    Service Name: MMS
    Server Name: http://mmsc.cingular.com
    Web Session Name: MMS
    Dec 17, 2007 | Motorola Mobility RAZR V3
    Cant pxt or recieve tone downloads (parallel import phone)
    Please verify that your settings are as follows, and then you should be all set!
    (if not there select "new")
    Port 1: 9201
    Service Type 2: WAP
    Port 2: 0
    DNS 1: 0.0.0.0
    DNS 2: 0.0.0.0
    Time out: 5 minutes
    Speed (Bps) 9600
    Line Type 1: ISDN
    Speed (Bps) 2: 9600
    Line Type 2: ISDN
    Password: CINGULAR1
    Press Done.
    Press Exit.
    Press Back
    Press Back.
    Press the Menu key.
    Service Name: MMS
    Dec 14, 2007 | Motorola Mobility RAZR V3
    Apple iPod nano Logo
    44 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
