SOURCE: moving maxi cosi to another car
I assume that you mean the Maxi Cosi Priorifix?
At the top of the leg (that extends to the floor of your car) there is a button (which, if connected to the Isofix points will be red) push this button in as far as it will go and the seat will release from the Isofix points.
I hope this helps.
SOURCE: maxi cosi cabrio fix fitting to renault laguna
I would suggest that you have this fitted by a trained car seat specialist, but you can check the compatibilty on the Fit Finder on this link.
http://www.maxi-cosi.com/maxicosi/carselector.aspx?language=gb-en
I hope this helps;
SOURCE: Hi, I just installed the
Hi - The yellow plastic guides are only for your conveniance if you need them. Some cars have very prominant IsoFix points and you do not need to use the guides - this is fine. As long as the indicators go green to show correct fitting it is fine.
