You need to turn on portable wifi hotspot in your wireless and networks menu. Go to portable wifi hotspot and turn on, leave settings as they are and make a note of the security key. Turn on wifi on your PC and search for your phone 'HTC portable hotspot' for instance and enter the security key you were given on the setup page. You should now be connected.
SOURCE: can't download compaq 754 tu laptop wi fi drivers
Hi
Try this link:-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3674870&lc=en&cc=us&dlc=en&submit.y=10&submit.x=2&lang=en&cc=us
SOURCE: Wi-Fi problem Toshiba A15-S157 laptop
If your laptop has a di-fi switch/button chances are you have one integrated on the main board of the laptop, check if the wi-fi adapter is installed properly by going to the Device Manager and check Network Adapters normally a wi-fi adapter will show up if not check if you have any devices listed under network devices(Network Controller, Ethernet Controller). Now if the wi-fi card is installed and the status on the Device Manager say's that it's working properly, you may now check your laptop for a 3rd pary wi-fi utility/application that manages your connection look for it on the System Tray on the lower right hand side near the clock or go to all programs and look for any WLAN utility, when you open the utility make sure the wi-fi radio is turned on or enabled.
SOURCE: Want Instant wi fi when turning on my laptop
Hp comes with a wi-fi utility and I dont find it very useful, so first, you might want to uninstall the software from add or remove programs and then use windows to manage your wi-fi.
Once you connect to a wireless network from 'network connections', it will automatically be set to default and should connect at the computer startup.
If it does not connect automatically.go to 'change order of prefered networks' and put your prefered network on top and set to automatically.
SOURCE: my problem laptop not working wi fi connection connect phone
ok.
its knows that vista isfull of bags and corraps.
the fing is a computer with vista req a heavy vid card such as 9xxx (dont go on 8800 it is waste of money) and you need 2-4 gb ram for your computer to work perfect and so the best fing you can do try to download windows7 beta it is like windows vista but acts like xp wich is the best so look for a good downloadand goodluck.
If you connect the phone to the PC via USB, you should also be able to turn on USB tethering to use the phones network.
