Question about JBL Encounter 2.1 Computer Speakers
Jbl encounter - loss of one channel ?
My left channel is not reponding (the speakers both work as i've checked)..what could be the problem and how do you open the sub woofer speaker!!? It looks airtight !
Thanks dave Black
  • fleetwoodbla Nov 06, 2008
    Control panel set to Line out for external speakers so that ok.
    Its a macintosh cpu so speaker minijack was in the correct output.
    Speakers were working fine then one of the channels just went with a slight crackle then lost it!
    So its really trying to find out how to fix a 'none responding channel' ?
    Thanks for the reply!
  • 3 Answers
Goto your control panel and set which type of speaker you r using
and get proper cable for connectivity to your cpu to speaker
and install matchable audio driver which suited to your hardware
one think you also check for your cpu is that
there are there pin in bihind your cpu one for dedicated to microphone
and other are used to get connected to speakers so let me know what socket pin and color r u using
ok and check correctly for your own knowledge
Posted on Nov 06, 2008
I have JBL encounter speakers and i want use them with my Mac, when i plug nothing comes out (sound)
Wanted to clarify , if the you plug in a headphone are you are able to get the sound from them . If yes than , you might need to check the connection on the speakers. If the headphones are also not working through the audio jack . You would have to check the following
1. Check if there is any external damage to the audio jacks both on the MAC and the JBL connector
2. Check if the sound properties on the MAC are configured correctly
3. Check if the sound card drivers are installed correctly.
Thanks for using fixya
Mar 13, 2012 | JBL Encounter Speakers Computer Speakers
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
I have jbl encounter speaker, my left speaker is very weak compared to the right channel. I can hardly hear the sound out of the left one.
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Sep 01, 2011 | JBL Encounter 2.1 Computer Speakers
I can not increase or decrease volume on my JBL encounter speaker system
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | JBL Encounter 2.1 Computer Speakers
Have a JBL Encounter 2.1 Multi Media Speaker System need to find a power lead and speaker jack for it im resident in uk and need voltage requirements regards
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
Mar 23, 2011 | JBL Encounter 2.1 Computer Speakers
This thing isn't build with jbl speakers! cuz i repire this sub 2 weeks a ago this sub was build by some kind of unbrand chines any one know about that..otherwise i heard jbl use onl JBL brand...
JBL is obviously just putting their name on your product. Just the way it is. They put their name on it, but use inferior parts. It is cheaper for JBL to have other folks make the stuff.
Oct 07, 2009 | JBL Encounter 2.1 Computer Speakers
Problems with int 5.1-Channel Home Theater Speaker System
yes u will need to chandge input jack from mono to stero radio shack $4 part u need y headphone splitter this should fix ur problem
Aug 07, 2009 | JBL 5.1-Channel Home Theater Speaker...
I couldnt adjust the volume with the JBL encounter speakers when i plug it in my laptop, but when i plug it in my iPod, i works perfectly... Can anyone help?
If you are using windows then go to
  • control panel
  • open-> sound and audio devices
  • a window will open showing your sound configuration
  • towards the bottom of that window, you would find speaker volume-click it
  • on the next window, click the button saying restore deafults
Now check the sound.
Hope, this helps.
Otherwise tell me.
Mar 29, 2009 | JBL Encounter 2.1 Computer Speakers
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
JBL Encounter 2.1 Computer Speakers Logo
244 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
