Question about ASUS G2P Notebook
Asus g2p max ram
Where are the 2 mem slots and what is the max ram i can put in thanks rskel
  • rskel Nov 04, 2008
    thks guys one more ? is there a way to get the g2p to take more mem like upgrading the bios or changing the op system
  • ASUS Master
  • 4,338 Answers
You got two memory ports. One on the bottom of the unit.The second one is on top of your Notebook. To reach it you have to remove the keyboard. There are three small points on the top of the keyboard to unlock it. Under the keyboard you will find a metal protector with one screw which protects the second ram...
By the way: The Bios only recognizes up to 2 of ram.
System Profile ASUS G2P Standard Memory 0 MB (removable) Maximum Memory 2.0 GB Slots 2 sockets System Notes PC2-4200/5300 DDR2 SDRAM SODIMMs
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 04, 2008
  • 488 Answers
Hi!here is the link for ur info http://www.crucial.com/store/listparts.aspx?model=G2P
its on crucial.com that is an amzing site for memory upgrades..your compu supports 2GB RAM max..do see the link for the type of RAM..the RAM is located underneath the compu and can be assessed by removing the screws..take care if ur planning to do it yourself..look at this http://www.computermemoryupgrade.net/installing-laptop-memory.html
regards!hope it helps!
Funny thing is I placed 2GB of RAM on the slot located at the bottom of the computer, I didn't know where the second slot was untill i read this post but come to find out that the computer does recognize at least 3 GB of RAM I do have an extra stick of 2GB, which I will now put in later on today I will keep you posted if my computer recognizes it or not.
But on a differnt note I am having an issue with my computer overheatting total unrelated from the post above this issue happened way before that. Does anyone know the part number(s) for the cooling fan or any other components that i might need to replace in order to get my computer back in great working order. Thanks for anyhelp that you can give me.
Posted on Apr 01, 2009
My asus p5q pro wont recognize 2 sticks of ram in the yellow slots but if i put one in yellw and one in black it recognizes them
is memory the same? probably not each slot set is for different memory need to add identical mem to slot yellow or black to increase mem.good luck!
Jan 08, 2011 | ASUS Computers & Internet
Asus M2V890 motherboard supports max 2GB memory per specs. Is there any way to increase this, or am I stuck with 2GB?
2GB is enough for the MB you are using, if there are no more slots on the MB then you cant increase them.....every slot has a MAX limit of RAM card that can be installed, check the MB specification....i guess 1GB per slot is the MAX...so 2 slots...2GB
Nov 18, 2010 | ASUS V2-M2V890 AMD SktAM2 Barebone System...
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Ram compatibility
No Sir, it will only support DDR / SD RAM. You can see the complete specs of your Board here.
If i was helpful, kindly do Rate! Regards.
Jul 31, 2009 | Computers & Internet
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Memory problem
The ASUS web site shows only two ram slots on the motherboard. Sounds as if the booklet has a misprint. Specifications on the web site list memory as: Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory. So, 2GB is max.
Jun 10, 2009 | ASUS P5PE-VM Motherboard
How much ram mem can i put into a compaq sr1000
It depends on which sr1000 you have, there are 5 in that serie.
How many memoslots di you have?
If you have 2, then it is max 2GB memory
If you have 4 slots, then it is max 4GB memory
The SR1000IL model supports 4GB, all the others supports 2GB
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 16, 2008 | Compaq Presario SR1000T (568657) PC...
Memory/RAM
you are probably not using the correct type of memory, if you just bought a 1 gb stick, Laptops are pretty picky about what memory they use, check the Kingston Memory configurator to find out the max installable mem and which mem is correct to use.  http://www.kingston.com/ukroot/default.asp  use the Memory search feature on the right of the page to get you started
Toshiba satellite is a seperate section in the configurator, so choose that line to get more choices
Oct 16, 2007 | Toshiba Satellite A60 Notebook
ASUS G2P Notebook Logo
1,073 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
