Question about Canon Office Equipment & Supplies
I think I need new rollers for my Canon Image Class D680 copier. When copying a stack of about 30 pages it missed several sheets.
Try cleaning the rollers first, with Isopropynol.
Posted on Nov 05, 2008
Where can I find 64 bit driver for Canon image Class D680 Laser Printer
Doesn't look like they have one, only 32-bit. Maybe they have some sort of universal driver you can use. Keep in mind this equipment came out in 2004.
Jul 18, 2011 | Canon imageCLASS D680 Laser Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I need a printer driver for a canon d680 image class printer for my MacBookAir pls
http://www.fixya.com/support/r1468656-free_printer_drivers_lost_driver
Sep 01, 2009 | Canon imageCLASS D680 Laser Printer
I have a canon image class d680. the machine no
Have you tried to clean the pick up rollers with a rag with a small amout of WD-40 or Simple Green. Clean the roller then whip off with a dry rag. If the problem improves you need to replace the pick up rollers. If not you may have to replace the paper feed clutch. Also, look to see if the seperation pad is ingaging when the paper tray is pushed in. Open the left side door. I've seen the actuator break. Also, have you tried to use the manual feed tray???? I know you made sure the paper guides in the paper tray are set correctly for the size paper in the tray??? Good Luck
Feb 26, 2009 | Canon Office Equipment & Supplies
CANON D680
I think that problem is in analog signal converter, below the copy glass. It does not convert light into the el. signal for machine.
Feb 26, 2008 | Canon imageCLASS D680 Laser Printer
Canon d680
try new cartridge. are you using new or remanufactured?
Nov 09, 2007 | Canon imageCLASS D680 Laser Printer
Printing and faxing more than one page at a time
Hi This is a common problem, not only with your printer, but most at some time or other. In part it seems you get what you pay for, in that if you buy premium paper (business grade 40 mil), you normally have less problems. The paper is drawn into the printer by a rubber or compacted foam roller, and sometimes the paper sheets will sick to each other, and more than one will be drawn in. The best thing to do if you are using less expensive paper, or even the expensive stuff, is to "fan" the stack of paper several times with your thumb, at the end that will face the rollers, and also don't let the stack get down to only 3 or 4 sheets, as the problem is worse near the bottom of the stack. Hope this helps. Good Luck!
Nov 30, 2006 | HP OfficeJet 6110xi All-In-One Thermal...
old marine
old marine
