Question about Saeco Magic Comfort Plus Espresso Machine
Rinsing...Warming UP... message on Saeco Magic Comfort plus
After replacing the boiler, I keep getting this message. Any thoughts ??
HI, I am sure you have solved your problem, however:
If you Descale the machine and let it Rinse to complettion of the
cycle; it resets the machine and it will start Rinising after warmup.
Otherwise press the Menu button and go to Energy Saving
then press the Esc buttton. This allows the machine to start
without Rinsing. Also you may turn Rinsing to Off in the Menu.
Posted on Oct 16, 2009
When I turn on the machine it says warming up and rinsing but it doesn't rinse and I can't get it to make a coffee it won't go past rinsing
Probably overheat protector thermal switches on the water boiler is tripped. Need to open the machine and reset those switches by pushing in the pins on the switches.
OR the element on the boiler is blown.
May 25, 2010 | Saeco Royal Digital Plus Coffee...
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
May 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort plus: Despite descaling the machine twice, the Descaling notice remains lit on my screen. Brews great coffee but what gives?
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Jan 09, 2010 | Saeco Magic Comfort Plus Espresso Machine
My saeco magic comfort plus is spilling water out through the bottom of the machine. there is water in the little hole next to the brewing mechanism.
water from under the machine is almost always the boiler.
In some rare cases it is the flow meter.
Needs to be sent in for repair.
Aug 07, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus machine has message "Ventillate" how do you clear this?
open steam knob and water need start going on steam wand keep going couple minuts and you will see machine is ready,if you still have same problem thats mean your flowmetar is not good
Aug 03, 2009 | Saeco Magic Comfort Plus Espresso Machine
Warmup never completes, no steam comes out
I think your model only has one boiler, it is possible that the thermostat for the steam could be damaged. or on the mainboard, connection that turns the steam on is damaged(I had that happen on a compact digital).
Jul 07, 2009 | Saeco Magic Comfort Plus Espresso Machine
Regarding Saeco Magic comfort + venting
It can be calcium in the boiler or in a tube, it can also be the flowmeter that have to be replaced.
If you take off the top you will see the boiler, loosen the tube to see if there are some calcium in this. If you see calcium around the boiler, then you have to replace it.
Best regards
Oct 12, 2008 | Saeco Magic De Luxe Espresso Machine
Ventilate message stays on
ventlate means run water through the steam pipe
like make water for a cup of tea
Sep 21, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort +
How old are your machine?
What number is the grinder on?
How often do descale the machine?
Aug 26, 2008 | Saeco Magic Comfort Plus Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
897 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
