Technics SCEH790 CD Shelf System
Problem for Technics SCEH790 CD Shelf System
Speakers cut out after about 10 minutes.
By soapy on Oct 03, 2006
I have the Technics SCEH790. After about 10 minutes the speakers cut out. If I then switch it off for a few minutes, then back on again it'll work for a few more minutes and then cuts off again. I have tried a new cooling fan, but it makes no diference. Any ideas? Please help.
Solution #1
posted on Oct 03, 2006
Somewhat Helpful)
gadget
Rank: Master
Rating: 75%, 76 votes
Even tho you have replaced the fan it will not cool the system down in time if it is your amp that has gone. This heats up so quick if there is something wrong with it and it will just stop the power from going to your speakers. Take it to a shop and get it looked at.
Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Oct 04, 2006
Not Rated)
Pravin
Rank: Wiz
Rating: 83%, 647 votes
Does the system perform normally- as long as it works? If yes, then the Amplifier is at fault. It cannot be the output Transistors or IC, as the sound is coming from both channels. If you know solid state servicing, I advice replacing all the electrolytic capacitors in the Output stages of the Amplifier.
Over a period of time these El Caps dry out, and cause headaches.
Was this helpful?
Yes
No
Popular Solutions for Technics SCEH790 CD Shelf
Questions and Unsolved Problems for Technics SCEH790 CD Shelf
Do you recommend Technics SCEH790 CD Shelf System?
Answer
Answer
need a new amplifer for a sh-eh790 as my main audio output has gone
Answer
Hi I have speakers SB-DV290d can I plug them into my existing system or do I need anything else?
Answer
hi guys iv been look for a remote control for my technics sc dv170 can any body help please
Answer
sound keeps going off on my technics sa-eh790 problem is the same whichever input is used the system... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio Shelf... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
