Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 55PW9363 Service Menu - Geometry settings help, picture shifting at times???
Hi, I have a 3 year old philips 55pw9363 and I have extended warranty. Convergence has gone bad and Im getting a new part from best buy. But I still have some problems. First, the picture shifts slights every once in a while. It happens with all inputs. Second, geometry seems to be off. The top and bottom in the middle come in, i think concave? I know you can fix through service menu but not sure what options. Any help would be appreciated. If anyone has any knowledge with the service menu geometry options. thanks.
  • Danny Muniz Oct 03, 2006
    If I go into the service menu and list the settings, would anyone be able to tell me what they mean? What I mean is like by setting v amplitude, etc?
    i fixed the over/underscan by going to service menu, i just wish i knew what those options meant.
    Sergeant:
  • 337 Answers
If you are doing the labor you should wait and replace the new part and while you are at it check for loose conections in the horizontal drive circuit since all symptoms might be related,but they are doing all the work they should address all the problems you have,settings in the service menu dont just change on their own and are adjusted only when a major comp[onent has been change like the convergence.
Posted on Oct 03, 2006
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 need convergence grid dimensions
You may not need a template as long as the geometry has not been totally lost or corrupted. How is the image in red and blue? If any of the three convergence/CRTs has good geometry, you can align the others to it. You can simply cover over any CRT whose image you wish to block out while you are aligning the others.
Feb 15, 2009 | Philips 55PW9363 55" Rear Projection...
Dptv335 Philips 55PW9363
i would send the board in for repair... ptscorp.com
Feb 13, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55pw9363 next problem
Have you change the RGB setting to Y/Yb/Yr?
You can change this option in the menu - install then go all the way to the bottom
Nov 17, 2007 | Philips 55PW9363 55" Rear Projection...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363
Hi! ronogre,
This set has a defective SMALL SIGNAL BOARD.
Toprol
Jul 31, 2007 | Philips 55PW9363 55" Rear Projection...
My TV is flashing a code
Try unplugging the set for 30 seconds then re-trying operations again.
Apr 10, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 55pw9363 factory default settings
Yes,there is almost always a way! you will need the CD ROM literature for your model--it will list the normal range of settings. My reserved question is what caused the overscan and why did you decide to go in the servicer menu to "fix" the problem???? You may have some convergence issue,also.
Oct 17, 2006 | Philips 55PW9363 55" Rear Projection...
Can APAC be disabled?
Yes, Turn off the convergance option.
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
545 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
