Question about Cell Phones
The volume is turned as high as it can go but if somebody rings me there is no sound
    Master:
  • 383 Answers
Either the ringer is at fault or the profile is set to light only
Posted on Nov 04, 2008
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
My phone doesn't ring to maximum volume, its too low.
Welcome to FixYa
Dear User,
You can Adjust your Ringer Level to High...If your Ringer is in Full Volume and No Sound/Bad Sound-the Problem is with Buzzer or Board Complaint[Board complaint in Rare Case]
Ringer Option in 6300:
  • Settings
  • Profile
  • General
  • 'Personalise'
  • 'Incoming Call alert'[Must be in RINGING]
  • Move to Bottom 'RINGING VOLUME'[move to Right side-now you can Hear Sound-Set to High Level or as you Like
  • It may ask for Confirm Selection of high Ring Vol
  • Alert For 'ALL CALLS'[at Bottom]
  • 'Save' Click
  • Then Activate GENERAL
You are Done[In this way -you can Select any Profile]
Hope this Helped -Dont forget to Rate ME......Thanks for Contacting FixYa...
Jul 09, 2010 | Nokia 6300 Cellular Phone
My ringer on my motorola droid will not ring how can i fix it? The vibrate works. When i turn the volume up it shows the volume is all the way up but still nothing when somebody calls me.
HI, You will need to unscrew the phone, and locate where the ringer is inside the phone. Is usually round in shape. Remove the old one inside and replace it with the new one.
I would advice,you phone is a little bit technical, if you don't have the experience to unscrew, please contact a technician for help, in other to prevent further damage.
Take care.
Jun 21, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
How can i turn the ring back on? when somebody call my phone doesn't ring , what can i do?
Usually on the wireless phone their is a button to adjust the volume. It may say loud ring or soft ring. Or ring on or off.
Apr 06, 2010 | Uniden Cordless Phone EXAI985
My LG Neon GT365 has no ringing sound. So when somebody called me I don't know about it.
I had the same problem where the ringer had no sound and someone suggested taking the battery out and then putting it back in and that corrected the problem
Mar 19, 2010 | LG Neon GT365 Cell Phone
My Jet ringtone volume is up full but still only
I too have this problem, I have reset the phone twice and that works to bring the volume back to the normal levels. However all my sounds on the phone are low, including the alarm. It wouldn't wake anything. Can somebody please explain how to return the volume without having to rest the phone. Thank you. J
Nov 17, 2009 | Samsung Jet S8000 Cell Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Cell Phones Logo
130 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
