Question about Samsung DVD-P244 DVD Player
I cant see pictures.
Hi there!, Mine is a samsung DVD-P246, I happened to set and entered a function that i did not know what it is about.Snce then my DVD cant display video. Can you please assist me! The path you provided n order to get solution contains no hepl!
2 Suggested Answers
SOURCE: HELP - Samsung DVD player P347
From the manual...
Connect the DVD to the TV via S-video or Video outputs (not component video) and...
• Press power on from a cold start with no disc in the unit. Press the
SEARCH/SKIP ( ) button on the front panel for 1 second.
The SELECT MENU LANGUAGE display will appear.
Select the number button of the desired language.
regards, Glenn
keraurus (at)
Posted on May 24, 2008
  • 11896 Answers
SOURCE: DVD samsung P231 does not play commerical level
You could have a faulty power supply, capacitor or control board. The laser lens circuit should be fine if the disc spins.
Testing of the circuit board and componenets such as capacitor and power supply will have to be done. Power supply can be tested with a voltmeter and capacitors with a cap tester or ohmmeter
Posted on Mar 28, 2010
0 characters
1 Points
I cant get a picture on my portable dvd only sound
see the remedies and fix it;
  1. Make sure all power cords are connected.or batteries
  2. Try pressing the enter/play key.
  3. Make sure the DVD is turned on and the input is set properly.
  4. Make sure the DVD source is set properly on the DVD (This is probably done on the screen; Check your DVD manual).
  5. see the block and test
Jul 20, 2012 | DVD & Blu-Ray Players
Parental lock on cant eject dvd
1 try un plug and plug back in
2 if not work enter menu and look for settings and look for parental lock or ratings most codes are 1234 / 0000 / 5555 or 8888 but if you changed code i will not know
3 open dvd and look for rubber belt and cog then turn it until dvd draw opens ( UN PLUG FIRST )
hope this helps
Dec 12, 2009 | JVC XV-N322 DVD Player
How do I set the clock on my DMR-E75V. Also, where can I buy a manual. Lost mine when shifting.
Press functions,select to others,press enter,select set up,press enter,select others,press right arrow,select clock,press enter,change automatic to on,this will then hold the time.
Oct 18, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Wuz n menu settings, hit wrong button, now only hve rolling pix!
you pressed the color system format button/settings.on the remote press the P/N which means pal/secam and it several times or until you get a steady picture.when its black and white then you can press the set-up or menu button to correct your settings.
May 18, 2009 | Cyberhome CH-DVD 300 DVD Player
How do I reset the Cyber Home 300 to defaults?
Check your owners manual. find the function by using the on screen menu, turn this on by pressing the menu button This function is usually in the setting functions and is usually found by using the up and down arrows to find the settings function and then using the right arrow to enter the function. After entering the function you should find the factory reset function among the listed settings.use the up and down arrows to find this setting and place the cursor on it and press enter and it should reset all the functions to the factory settings for you. Hope this helps you with your problem.
Apr 19, 2009 | Cyberhome CH-DVD 300 DVD Player
Password unknown
  1. Press power on from a cold start with no disc in the unit.
  2. Press the STOP and PLAY buttons simultaneously on the front panel for three seconds. “All setup value will be reset to factorysettings. Your player will be shut off.” will appear.
  3. Press the MENU button on the remote control to select the Parental Mode. The Parental Mode is now unlocked as indicated on the display.
  4. Press the DOWN button to select Parental.
  5. Press ENTER and the Password Check display will appear.
  6. Enter the default password of “9999”.
  7. You can now set your rating level and change your password to a new number.
Mar 13, 2009 | Samsung DVD-N501 Nuon DVD Player
I,ve touch a function and my dvd plays but it is Black and White and the image rotate, I know that I went into picture ...i believe and set it to something else cannot bring it back to normal function DVD...
yes , i can help,> open dvd tray, your player will go to menu but it will be jumping so look to bottom of screen to tell what function you are in. scroll down till you see "display lets you display picture etc." when you see this at bottom of screen hit enter and and hit bottom arrow you will see pal/ntsc option hit enter again and your picture will return to normal good luck.
Nov 26, 2008 | Koss KS3112 DVD Player
HCT DVD recorder: HDVR-960s
I purchased this same unit yesterday from the PX Power Zone. I hooked up the unit and even managed to record a few minutes of a show. I then went into setup and made a few changes. Now, I have no display at all from the unit. Does anyone know how to reset the unit back to factory settings? Please email me at Many thanks!
Nov 04, 2007 | Samsung DVD-R155
Display says "LOCKED", won't eject disk, all other functions work. Need unlock procedure.
How I got my DVD from ”lock” condition
My DVD (Panasonic m: DMR-ES10) had gone to ”locked” condition without any warning.
Perhaps the reason was that I transfered the machine when it was on and recording was going…
Guidebook didn´t help to resolve the problem, neither Internet. Finally I managed to solve the promlem . This is how i did step by step:
1) Power on
2) Hello
3) read
4) no disc
5) functions
6) to others
7) setup
8) select down arrow
9) disc
10) select right arrow
11) setings for playback
12) enter
13) ratings (level8)
14) enter
15) No limit
16) enter
17) ”The Recorder is now unlocked” (picture of open lock)
18) enter
19) return
20) return
After this DVD works normally.
Aug 11, 2007 | Sony DVP-S330 DVD Player
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. "setup" "down arrow"(selects audio/video) "enter" (selects audio/video menu) "down arrow" 4 times (selects scan mode) "right arrow" (selects scan menu) "up arrow" (selects interlace mode) "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
Samsung DVD-P244 DVD Player Logo
32 people viewed this question
Top Samsung DVD & Blu-Ray Players Experts
Are you a Samsung DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
