Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Print problem my system is not print what do i do
If my system is not on. what do i do
Posted on Nov 07, 2008
Thanks you for answer me
Posted on Nov 06, 2008
First remove drivers from ur systems and then re install drivers and then print it if u got again same problem then fromat ur system and install drivers that its
Posted on Nov 05, 2008
Unable read cups raster data os lexmark
It's a Driver issue. You need to reset the printing system by deleting the current printer and re-adding it, like this:
  1. Click the Apple menu, and then click System Preferences .
  2. Select Print & Scan.
  3. Right-click (or Ctrl + click) your product in the Printers list in the left panel, and then click Reset printing system .
  4. Click OK to confirm the reset.
  5. Type your user Name and Password .
  6. Click OK . The printing system resets.
  7. Next go to the Library\Printers folder and move the Lexmark folder to the trash.
  8. Under Print & Scan, click the plus sign and re-add the printer.
  9. The drivers should be reinstalled automatically.
Oct 31, 2013 | Computers & Internet
Tip
How to remove the Print Drivers from Windows 7 machine
aulty print drivers can give you a lot of headaches. In my case, print spooler was constantly crashing, or it was crashing when I tried to open Print Properties of the Print Device.
Since the problem is mostly in a faulty print driver here are the steps on how to remove the print driver from Windows 7. Procedure is slightly different from previous Operating Systems as now we'll have to use the Print Management tool.
Click Start (Win Orb)
Type: 'Print Management'
In the left pane navigate to: Print Servers ' PC Name (local) ' Drivers
Delete the faulty print driver, or if you're not sure, delete all of the Print Drivers listed.
Restart and try to download another/updated driver for your printer from the manufacturer's web site.
on Nov 24, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to make your printer print again on a MAC OS X
If you can’t print and you’ve tried other solutions, reset the print system. The process deletes all printers from your Printer list, deletes information about all completed print jobs, and deletes all printer presets.
1.) Select Apple menu > System Preferences and click Print & Fax.
2.) Hold down the Control key as you click in the Printer list, and choose “Reset printing system” from the pop-up menu that appears.
3.) then, Add the printers you use.
on Dec 22, 2009 | Computers & Internet
Can't open a newsletter in The Print Shop 22, Get a PMW error. Must get this newsletter to printers on Wednesday...urgent. Using XP.
Hi
I suggest you run the SYSTEM RESTORE. Go to START, ACCESSORIES, SYSTEM TOOLS AND CHOOSE SYSTEM RESTORE. The choose the previous date that your Print Shop is working fine.
Please post comments if you need more help. Regards
Apr 04, 2011 | Computers & Internet
Printer is printing foreign looking characters all on its own. No print jobs are being sent to the printer. Printer is set to DEC mode and the macro has been reloaded several times. As soon as you put the...
It sounds like data is being received by the printer from an outside source.
Try disconnecting the printer from the computer system so it is a free standing printer. Power the printer ON and put in ONLINE if you do not get strange characters printing the print job is definitely from the computer system some place.
If you do not get the print jobs printing when the printer is disconnected from the computer system, it could be that the print jobs are being sent from the wrong driver or print queue on the system, you may need to try to identify who is sending the rogue print jobs.
Feb 10, 2010 | TallyGenicom LA800+ Matrix Printer
System error
System error upon print option may be caused due to:
  • Improper device driver (printer).
  • Any corrupt file.
  • Any hardware error
Check all these before you start printing, Try to check a test print also..
Jan 21, 2010 | Brother P-Touch PT-2600 Printer
Using Windows Vista, documents remain in the print queue after printing necessitating that the computer be restareted between every print job. Is there a fix?
Hi jonty143, you can try these steps.
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 13, 2009 | Dell A940 All-In-One InkJet Printer
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Not Printing. Reinstalled the software, reset printer to factory
If you are running Leopard, reset the printing system by control-clicking in the list of printers in the Print & Fax preference window. Then reinstall the drivers.
Apple Menu > System Preferences > Print & Fax. Control Click in the left area which shows the list of printers, and choose "reset the printing system"
macs2u
Apr 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
